> Gas leak?
post Dec 27, 2009 - 12:38 AM
sarasa
Joined Dec 26, '09
From Ohio
Not sure where to post this and I just want some thoughts on the issue on what it might be. I know it's vague and impossible to diagnosis without actually seeing the car.
When I first bought the car, I noticed it would smell like gasoline if I filled the tank and waited for the gas pump to stop for it to be full. It smelled of gas really bad and it would happen only when I filled the tank completely full. One guy who changed my oil thought it was a hole in the gas tank. When we took it in to get an estimate, they put it on a lift but told us that they couldn't tell what the problem was without taking the car apart. They also noticed gasoline down the side of my gas tank. I've filled it 3/4 to 7/8ths full and I haven't smelled fumes. I also don't notice a decrease in my gas mileage, but I cant estimate it accurately.
Would a hole be dangerous to drive around with? Could the car explode? Sort of silly question but I read online somewhere it is a possibility. If it was a hole though, wouldn't I smell fumes more often other than filling the tank completely?
post Dec 27, 2009 - 12:01 PM
Tech-Nics
Joined Jun 18, '08
Had the same problem the other day turned out to be the filler neck. The filler neck is the pipes that go from the gas port you fill the car with gas to the fuel tank under the car. It seems to be very common for car's fill necks to completely rust and start to break apart causing little leaks and seeing how strong the smell of gas is you can get a heavy whiff of gas from a small leak. Just my assumption go check your filler neck its behind the rear driver's side wheel. You have to get under the car from the back.
Lo-Fi Version Time is now: November 30th, 2024 - 9:19 PM
