> Power locks, windows don't work in cold., I need a solution
post Dec 31, 2009 - 12:15 PM
A_N_T_H_O_N_Y
Joined Aug 29, '09
From Ottawa, ON, Canada
I live in Ottawa, Canada, and we get really harsh winters. On some days in the winter, the temperature can even drop to -30°C (-22°F).
Yesterday, it was -10°C (14°F), and I had my celica parked outside my work for about 5 hours. When I went to get in my car at the end of my shift, the locks wouldn't open. When I pushed the unlock button on my remote, I could hear the locks opening, but they wouldn't turn all the way, so I still couldn't get in the car. I tried using the key to unlock the door as well, with no luck.
I ended up having to open the trunk and hop over both seats to get to the driver's seat so that I could get home.
The same thing happens with the power windows. When the car has been sitting in the cold, they don't open. Also, for the locks, the driver's door seems to get stuck more often then the passenger door.
So I have no idea what to do. The only solution I can think of at the moment is to not lock my doors when it's cold. Has this problem happened to anybody else? Our winters last pretty long too, so I have to figure something out...
post Dec 31, 2009 - 12:19 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
post Dec 31, 2009 - 12:23 PM
A_N_T_H_O_N_Y
Joined Aug 29, '09
QUOTE (garin @ Dec 31, 2009 - 1:19 PM) *
Haha well you know, you never know when you need to, um, air the car out. lol
but yeah the windows aren't a big concern, just the locks.
post Dec 31, 2009 - 1:54 PM
pyeatts
Joined Jun 9, '09
From Saint Louis
The story is the factory grease on the lock actuators and window guides is freezing. There's only one real fix and that is to remove the door panel and use a a spray grease cleaner to remove the factory grease and replace it with a spray white lithium grease with teflon. It won't freeze and you shouldn't have this problem again.
post Dec 31, 2009 - 3:10 PM
A_N_T_H_O_N_Y
Joined Aug 29, '09
QUOTE (pyeatts @ Dec 31, 2009 - 1:54 PM) *
Perfect, that's exactly what I needed. I'm going to try this sometime this week and see how it goes. I'm assuming I can get the lithium grease from Canadian Tire, or a hardware store? Hopefully this will work. Thanks a lot.
post Jan 1, 2010 - 3:39 PM
RoyO
Joined Jan 8, '09
From Netherlands
QUOTE (pyeatts @ Dec 31, 2009 - 8:54 PM) *
Indeed, I would do the same! Thats a good solution..
post Jan 1, 2010 - 4:43 PM
lilgreenyoda
Joined Jan 22, '07
From Loveland
So are you saying that the drivers door gets stuck closed more often than the passenger... as in like when they're unlocked you still can't get 'em open? Or is it just the whole getting 'em unlocked thing?
post Jan 1, 2010 - 9:24 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Driver's door has been locked/unlocked and opened/closed more than the passenger side, it'll wear out its lubrication sooner. I'm dealing with something similar, as my power door locks aren't quite unlocking the driver-side door enough. It's literally about a millimetre or two of movement I'm missing, and it only affects opening the door with the exterior handle. Using the key to unlock avoids the issue.
post Jan 2, 2010 - 12:02 AM
zfjohnson07
Joined Apr 11, '09
i had that happen to my car in TEXAS!! it was so cold i stuck the key in and i bent the key trying to get the lock to turn, i had to get my gf to climb through the back and i had 2 car seats in the back at the time lmao so it was not an easy task!!
Lo-Fi Version Time is now: November 22nd, 2024 - 11:39 PM
