> Alternator? or battery?, im not sure which one
post Jan 1, 2010 - 4:30 PM
Goonter
Joined Nov 27, '09
From Canada
ok im not sure which one is busted but i'm thinking the alternator. last night came from a new year's party and i started my car. all of a sudden the battery light came on, which was weird cause the car was already running and it should've been charging while the car was on. so i went to my gf's house and slept over. this morning i started my car , battery light was on yet again. then i went inside to let my car warm up.. i went back out after 10 minutes and my car was dead. i found it weir again cause the car was running and the battery shouldve been charging. i tried to start the car again but no cranking or anything. but when i get a boost from a battery pack the car starts up no problem. so do you guys think it's the alternator? thanks in advance for the input
post Jan 1, 2010 - 4:36 PM
sounds like the alternator.
post Jan 1, 2010 - 4:40 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (lagos @ Jan 1, 2010 - 5:36 PM) *
if it starts and runs then dies, yes its the alternator
once the veicle runs the alternator powers the circuit, in the event that the alt isn't drawing enough the battery will compensate for it.. of course if the alt is basically shot the battery will jsut get drained *bat light*
without a doubt ur alt is shot
post Jan 1, 2010 - 4:41 PM
Goonter
Joined Nov 27, '09
From Canada
anyone know how much an alternator would cost brand new OEM? ball-parked
post Jan 1, 2010 - 4:54 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
as low as 20 and as high as 80, of course this is ebay so not sure of autozone, just click herehere
2001 Solar yellow Lexus IS300
post Jan 1, 2010 - 4:58 PM
EKAn
Joined Apr 24, '07
From CA
Does anyone know if an alternator from a 3sgte fits on a 5sfe?
what hes saying is if you put blue lights in you car youll lose hp.
post Jan 1, 2010 - 5:10 PM
QUOTE (Mstoochn @ Jan 1, 2010 - 4:40 PM) *
The battery light doesn't come on when the battery is dead. It comes on when the alternator produces less than 10v. It should actually be renamed the alternator light, as thats what its really for.
So if your car is running, and the alternator light is on, then you need a new alternator or something happened to your wiring connection.
post Jan 1, 2010 - 6:07 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE (Goonter @ Jan 1, 2010 - 4:41 PM) *
http://www.autozone.com/autozone/catalog/p...amp;totalPages=[I@1667bcc&currentPage=1&vehicleNValue=&navValue=15700086&parentId=57-0&fromString=&fromWhere=&filterByKeyWord=&categoryNValue=&categoryDisplayName=Electrical+%26+Lighting&_requestid=857286
160 after 80 core @ autozone.
QUOTE (EKAn @ Jan 1, 2010 - 4:58 PM) *
yes
Damn D-Man - most impressive.
post Jan 1, 2010 - 6:10 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
QUOTE (lagos @ Jan 1, 2010 - 6:10 PM) *
My F/S Thread!
Ferdi says (11:29)
post Jan 1, 2010 - 8:02 PM
lilgreenyoda
Joined Jan 22, '07
From Loveland
People might not be able to see what a lit up version of an alternator is though. Lol even I might be like "What the hell is that?" depending on how that light might be depicted.
But yes. Alt is the culprit. The 3s alt should fit, but a "high output" alt you could use also, is the alt from the 2.2l Camry as it has the same engine. Camry has higher output alt for a few reasons, but it'd work.
Lo-Fi Version Time is now: November 27th, 2024 - 12:43 AM
