still cant get the idle right |
Jan 2, 2010 - 8:11 PM |
Enthusiast Joined Apr 6, '09 From Mass Currently Offline Reputation: 0 (0%) |
ok first off, my 94 celica gt, is there one or two o2 sensors, i can only find one. second, my idle is still way too high, cant find a vacume leak, o2 seems functional, no engine light, but im still idling at 1100-1400
Jan 2, 2010 - 8:24 PM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
ok first off, my 94 celica gt, is there one or two o2 sensors, i can only find one. second, my idle is still way too high, cant find a vacume leak, o2 seems functional, no engine light, but im still idling at 1100-1400 only one o2 sensor, adjust the idle screw above the throttle body -------------------- Breaking Axles...
Jan 3, 2010 - 1:52 AM |
i have adjusted the throttle positioning sensor, still no luck
Jan 3, 2010 - 9:01 AM |
someone needs to verify this... is there an idle position screw on the throttle body?? i thought it was pre 96 that had them... been around the 3s too much...
(not the sensor, the actual idle position) -------------------- Breaking Axles...
Jan 3, 2010 - 3:53 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
someone needs to verify this... is there an idle position screw on the throttle body?? i thought it was pre 96 that had them... been around the 3s too much... (not the sensor, the actual idle position) No only on 5th gens they had that idle screw. -------------------- "To Protect And To Serve The Wealthy" -POLICE
Lo-Fi Version | Time is now: December 3rd, 2024 - 10:04 AM |
