need help wiring nightmare |
Jan 4, 2010 - 8:56 PM |
Enthusiast Joined Jul 5, '08 From Scranton, Pa Currently Offline Reputation: 0 (0%) |
i have a 97 with the 7afe the car had a small fire and burned the engine wiring. so now im trying to take a 95 wiring harness and a 97 harness (whats left of it) and make one but i cant find a wiring diagram for the 97 with the 7a can anyone help. ooh and the 97 is an auto trans and the 95 was a stick. im lost PLEASE HELP
Jan 4, 2010 - 9:08 PM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
what part burned??
what you're doing may be impossible... 97 has more sensors since its OBDII while 95 is OBDI This post has been edited by pittfirefighter: Jan 4, 2010 - 9:09 PM -------------------- Breaking Axles...
Jan 4, 2010 - 9:10 PM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
x2. It may be cheaper and easier to just call up your local junk yard and order a 96-99 engine harness.
-------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Jan 12, 2010 - 1:46 PM |
Enthusiast Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
If you end up still needing a wiring diagram i'll print you one out from On demand if its needed.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Jan 12, 2010 - 1:58 PM |
Enthusiast Joined Jul 23, '09 From Fresno, Ca Currently Offline Reputation: 6 (100%) |
If you end up still needing a wiring diagram i'll print you one out from On demand if its needed. HEy, im sorta in the same boat. My current car 95 stick st wiring is all brittle and old. i want to use my stock cars wiring, but its a 96 st AUTO.. but thats not possible? is there any wiring I can use? my 96 is in waaaaaaay better condition, and would like to swap as many parts from it to my current 95 as possible.... |
Jan 12, 2010 - 9:58 PM |
same problem OBDII vs OBD I
Jan 15, 2010 - 2:18 PM |
your better off going on car-part.com and looking for the wiring harness for your exact model and trans. I've tried rigging two different harnesses together for a 4x4 suburban, it didn't work out to well
Lo-Fi Version | Time is now: January 13th, 2025 - 9:43 AM |
