WTB: 5SFE Igniter/ coil igniter, **edit: as well as some sensor connectors |
Jan 6, 2010 - 6:10 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
good working condition igniter, the one above the brake master cylinder.
non-brittle locking: -oil pressure connector -distributor connector, 4pin and the other one -oxygen sensor connector (top 1st sensor area) -igniter coil connector (above brake master area) if possible could you include pigtail wiring with the connectors Much Alohas This post has been edited by 808celica: Jan 6, 2010 - 8:03 AM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jan 6, 2010 - 4:24 PM |
Enthusiast Joined Jun 1, '08 From STL Currently Offline Reputation: 0 (0%) |
good working condition igniter, the one above the brake master cylinder. non-brittle locking: -oil pressure connector -distributor connector, 4pin and the other one -oxygen sensor connector (top 1st sensor area) -igniter coil connector (above brake master area) if possible could you include pigtail wiring with the connectors Much Alohas Gotta P/N? I might have it for you. |
Jan 6, 2010 - 5:27 PM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
i have everything mentioned....
send me a PM i actually have three or four of everything mentioned so i can get you the best looking ones i'm parting two celicas and i have two full 5sfe harnesses This post has been edited by pittfirefighter: Jan 6, 2010 - 5:29 PM -------------------- Breaking Axles...
Jan 6, 2010 - 7:03 PM |
Gotta P/N? I might have it for you. http://www.6gc.net/forums/index.php?showtopic=71470 posted p/n here but i dont know if they're the right ones cuz my lack the proper name and diagrams gone on toyodiy i have everything mentioned.... send me a PM i actually have three or four of everything mentioned so i can get you the best looking ones i'm parting two celicas and i have two full 5sfe harnesses sent thanks This post has been edited by 808celica: Jan 6, 2010 - 7:04 PM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Lo-Fi Version | Time is now: November 22nd, 2024 - 8:26 PM |
