Lagos' ct20b install |
Jan 8, 2010 - 10:47 PM |
Here are the pics from the install...
I decided to remove just the turbo and not the entire exhaust manifold, to help avoid any issues with stripped exhaust studs. I also had a brand new Hose from Hell that has been sitting in my house for months waiting for this day.... and wouldn't you know it, I didn't think of bringing it with me to my friends house where the installation took place. oh well. Removing the ct26... Here is an interesting picture of the effects of washer fluid injection over a period of time. the turbo on the left is the new ct20b and the turbo on the right is my ct26. You can clearly see a white precipitate that has formed as a by product of mixing washer fluid into the combustion chamber. It also looks like there is a bit of an uneven distribution of the washer fluid as cylinders 1 and 2 have a lot more of the white percipitate than cyl 3 and 4. the ct20b installed... Sam buttoning a few things up... car finished as if nothing ever happened... -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 8, 2010 - 10:52 PM |
I also decided to take this time to install an st205 crash bar and frame brackets, and build a new mount for the intercooler.
Here is the modified gt crash bar with the intercooler bracket I originally made.. Sam had some steel laying around, so we decided to make a new intercooler mount of it of. The intercooler basically sits ontop of these 3 brackets that bolt to the front of the car. I plan to paint them black in the future. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 8, 2010 - 11:32 PM |
congrats Art
Jan 8, 2010 - 11:36 PM |
How's the CT20 feel compared to the CT26?
Jan 9, 2010 - 12:06 AM |
Enthusiast Joined Nov 30, '04 From Atlantic City Currently Offline Reputation: 21 (100%) |
very nice.
Jan 9, 2010 - 1:06 AM |
Enthusiast Joined Mar 19, '07 From Washington Currently Offline Reputation: 9 (100%) |
Nice!
Why'd you decide to go CT20? -------------------- |
Jan 9, 2010 - 7:20 AM |
at least your current HFH looks to be in decent shape, art.
looking good man, ya think the white residue is possibly from any detergents or anything that may be in the WW fluid? when i pull the car apart in a few months, ill take a few pics of mine as well for a comparison -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jan 9, 2010 - 10:36 AM |
at least your current HFH looks to be in decent shape, art. looking good man, ya think the white residue is possibly from any detergents or anything that may be in the WW fluid? when i pull the car apart in a few months, ill take a few pics of mine as well for a comparison it could be just a byproduct of the methanol burning or perhaps detergents. I took chemistry last year and a white precipitate is very common when certain chemicals burn, just not sure whats causing it. Only thing thats interesting is that the port that comes from cyl 1-2 is a lot whiter than the port from cyl 3-4. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 9, 2010 - 11:06 AM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
I wonder what kind of effect that white residue has on o2 sensors. Why dont you try running a mix of straight methanol with water and see if that gives the same effect?
Jan 9, 2010 - 11:19 AM |
I wonder what kind of effect that white residue has on o2 sensors. Why dont you try running a mix of straight methanol with water and see if that gives the same effect? I have been running the injection for years, and never had any issues with my o2 sensors. So its safe to say its fine for that. Probably not going to remove the turbo again just to check a different mixture. There is really nothing wrong with the white residue, just something that happens. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 9, 2010 - 12:41 PM |
How's the CT20 feel compared to the CT26? My initial impressions weren't that great after my first ride, however after playing around with my EBC and adjusting the gain for this turbo's waste gate along with turning up the boost... here is what i think... After the very first start up of the car with the new turbo, I could notice this turbo flows a lot better and spools faster. Even by reving the car while its stationary, I could feel that the engine reved up faster and the bov was pushing out more air. You really need to make sure you have a boost controller (as most of us do except for joe!!!). Around 15psi on up is really where you will see the most benefits from the ct20b. The ct20b spools a lot faster than the ct26. Even just daily driving at part throttle you can tell the whole car has more power and is more fun to drive. The ct26 has a very limited power band. You make all of your power from 4k-5k and then everything starts to drop off, where as the ct20b continues to keep pulling harder and harder the longer you stay in it...like a car should. Over all, I have to admit that the car is pretty quick. It really surprised me after I dialed in the boost controller and was driving home one night. The car pulled really hard and torque steer was more noticeable (in a good/fun way!). If I had to guess based off my but dyno, Id say the car is at around 270hp and has plenty of fuel to make more power, but might be octane limited without alcohol injection. Bottom line is, if you have a 2nd gen swap. Upgrade to this. Its well worth it. This post has been edited by lagos: Jan 9, 2010 - 12:46 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 9, 2010 - 4:34 PM |
Enthusiast Joined Sep 22, '08 From Bergenfield Currently Offline Reputation: 5 (78%) |
Bottom line is, if you have a 2nd gen swap. Upgrade to this. Its well worth it. Agreed. CT20B is the BEST turbo for a GEN2 still on the stock ECU/injectors. --------------------
Jan 9, 2010 - 7:35 PM |
Enthusiast Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
nice my man im glad your enjoying it...im looking forward to putting it on my car after we take it to the dyno and pump out some numbers....and also get my car in order as well.....crash bar looks great too...over all, for an old head., id say not bad, little long on the install though...hahah
-------------------- I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Jan 9, 2010 - 8:01 PM |
, little long on the install though...hahah easy to say for a guy who didn't come by and help! -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 10, 2010 - 1:03 PM |
Enthusiast Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) |
How's the CT20 feel compared to the CT26? My initial impressions weren't that great after my first ride, however after playing around with my EBC and adjusting the gain for this turbo's waste gate along with turning up the boost... here is what i think... After the very first start up of the car with the new turbo, I could notice this turbo flows a lot better and spools faster. Even by reving the car while its stationary, I could feel that the engine reved up faster and the bov was pushing out more air. You really need to make sure you have a boost controller (as most of us do except for joe!!!). Around 15psi on up is really where you will see the most benefits from the ct20b. The ct20b spools a lot faster than the ct26. Even just daily driving at part throttle you can tell the whole car has more power and is more fun to drive. The ct26 has a very limited power band. You make all of your power from 4k-5k and then everything starts to drop off, where as the ct20b continues to keep pulling harder and harder the longer you stay in it...like a car should. Over all, I have to admit that the car is pretty quick. It really surprised me after I dialed in the boost controller and was driving home one night. The car pulled really hard and torque steer was more noticeable (in a good/fun way!). If I had to guess based off my but dyno, Id say the car is at around 270hp and has plenty of fuel to make more power, but might be octane limited without alcohol injection. Bottom line is, if you have a 2nd gen swap. Upgrade to this. Its well worth it. Well, I have to say I'm sold now. I have been holding back on the ct20b cause I wasn't sure if it its all that people make it to be. But with your review, I now believe! Part of the hold back also is cost b/c I have been thinking maybe getting the 3rd gen might be a better deal if one can get it under$ 2k. But it hard to just get rid of my 2nd gen that is running so superb, except for the frequent clutch breakdowns. I guess now I have some serious thinking to do. Thanks for your impressions. I have been waiting for this. -------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
Jan 10, 2010 - 7:37 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Eli, you should just go with competition clutch. They have worked wonders for me. At-least you haven't snapped any axles.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Jan 11, 2010 - 8:48 PM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
Eli, you should just go with competition clutch. They have worked wonders for me. At-least you haven't snapped any axles. that is a terrible idea... completely terrible -------------------- Breaking Axles...
Jan 12, 2010 - 8:43 PM |
Eli, you should just go with competition clutch. They have worked wonders for me. At-least you haven't snapped any axles. Hey Will, You know I have. I got one from Doc rated at 300lbs of torque and that broke into pieces after like 6months. then I went clutchmaster and the spring came loose on that one. Now I just installed ACT 6puck in a little over month ago. Praying this one lasts. I have never had this much clutch problem until I swapped. As a matter of fact, all my cars since 1994 have been manuals and I have never had any clutch break downs. I have changed driving habits going easy on it but to no avail. I'm beginning to think the car is making more than the clutches are rated for? . I have been thinking going 153 tranny and clutch, but its just too much hassle with the axles thingy and having to go thru all that every time axle goes out. Anyway, thanks for the advice though. I will be in MN in march (second week) on vacation maybe we can set up some meet? Eli Eli, you should just go with competition clutch. They have worked wonders for me. At-least you haven't snapped any axles. that is a terrible idea... completely terrible Whats up? I'm sensing bad experience with them? -------------------- 3sgteing.
Jan 12, 2010 - 11:43 PM |
Enthusiast Joined Dec 20, '07 From Valkeakoski, Finland Currently Offline Reputation: 0 (0%) |
thought Id share my experiences, im running around 18,5psi on my CT20b, and its much better than the st185 I´ve driven couple times, as it has the CT26..
I thought I´d ask, how much torque does the standard clutch handle? Guess I should be buying new clutch before more power goodies.. -------------------- |
Jan 13, 2010 - 3:49 AM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
I wonder what kind of effect that white residue has on o2 sensors. Why dont you try running a mix of straight methanol with water and see if that gives the same effect? I have been running the injection for years, and never had any issues with my o2 sensors. So its safe to say its fine for that. Probably not going to remove the turbo again just to check a different mixture. There is really nothing wrong with the white residue, just something that happens. So the white residue is from a mixture of the liquids? Or is it fuel deposits? I am just asking, I wouldn't know. Also, I wanted to ask if you or anyone else happens to know what the difference is between the CT20b and CT26? Because people are telling me after switching to CT20, it pulls so much harder and it allows them to boost at higher psi. Is it just cheaper to buy a CT20 and run with that? Or is it actually better? Because I see what kind of HP upping the trim on a CT26 to 47,50,56 and 60-1 and it looks pretty good, especially for just driving on the street (way better than that actually). Because I don't know much about turbos, but by comparison, the housing appears a bit of the same. I ask because the only turbo car I have right now is my MR2 and it has the CT26. I haven't had a chance to see what the Japanese ones have, however I noticed that on a stock vs stock test, they are faster than the Supra RZ MKIV in the 1/4 mile test. I thought the Supra uses the CT20 as well. So I just wanted to be schooled a bit. -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Lo-Fi Version | Time is now: November 26th, 2024 - 4:09 PM |
