> Another 7th gen airbag splice question
post Jan 10, 2010 - 8:15 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I'm swapping my 4 spoke wheel for a 3 spoke wheel, and the airbag connectors of course don't match up. The wires from the connector that runs to the airbag module are blue and yellow. If I used the multimeter right, I've determined blue is power and yellow is ground.
The wires on the wheel connector are red and black though. I would assume that red is power and black is ground, but when I connected them the airbag light stayed on, so I switched it and ducked, no airbag deploy but the light is still on.
Can anyone confirm if the 7th gen airbag connector is indeed red for power and black for ground? And if so, do I need to reset the airbag ECU after splicing in the connection? Thanks
post Jan 11, 2010 - 12:33 PM
GriffGirl
Joined Feb 7, '07
No one? Smaay, where are ya! I KNOW you know the answer to this. Come ON, peeps! tongue.gif
post Jan 11, 2010 - 2:33 PM
Culpable04
Joined Apr 17, '06
From New Jersey
you need to reset the airbag ecu, you had it right teh first time, just have to find out how to reset the airbag ecu
post Jan 11, 2010 - 4:56 PM
GriffGirl
Joined Feb 7, '07
Cool, okay. I've got instructions on how to reset the airbag ECU, so I will do that and cross my fingers biggrin.gif
Edit: Hey, so when you reset the airbag, did you use a paper clip in the terminals as though for the same process of resetting the ECU? Thanks for posting, by the way. I was a little nervous driving to work this morning!
This post has been edited by GriffGirl: Jan 11, 2010 - 5:17 PM
post Jan 11, 2010 - 7:22 PM
GriffGirl
Joined Feb 7, '07
Okay so I reset the airbag as per the instructions below, and it works, but the light comes back on when I start the car. Any thoughts or ideas beyond just checking to make sure my connections are secure? Light is on continually, no flashing. I'll try it again tonight, this time with two jumper wires from the ground terminal, to ensure I'm not waiting too long between grounding the DLC jumpers.
CLEARING CODES
1) At DLC, connect a jumper wire to terminal Tc. See Figs. 11
and 12. Connect another jumper wire to terminal AB. Turn ignition
switch to ACC or ON position. Wait about 6 seconds.
2) Starting with terminal Tc, apply body ground alternately
to terminal Tc and terminal AB twice each, in cycles of 1/2 to 1 1/2
seconds (sequence is: Tc, AB, Tc, AB). Finally, keep applying body
ground to terminal Tc until air bag warning light flashes quickly,
indicating codes are cleared.
NOTE: When alternately connecting jumper probes to terminals,
simultaneously release one probe from one terminal while
connecting other probe to other terminal. If time interval
between probings exceeds 0.2 second, codes will not clear.
post Jan 17, 2010 - 11:03 AM
abraxxa
Joined Nov 27, '05
From Vienna, Austria
Where did you find the instructions?
Are they included in one of the Toyota manuals?
Do you have the pictures mentioned in the text as well? (Fig. 11 and 12)
cya, abraxxa
post Jan 17, 2010 - 12:44 PM
FORGMANN
Joined Dec 11, '04
From USA
you don't need to splice any wires just buy this adapter
have to order from here not your dealer ..
http://toyota.spx.com/detail.aspx?id=407&p=173&g=21
This post has been edited by FORGMANN: Jan 17, 2010 - 12:45 PM
Old guy with the toys
95 ST205 WRC (the real deal)
94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned
post Jan 18, 2010 - 4:01 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
awe sorry Michelle, i need a PM. when i installed mine, i just unhooked the battery. cut and soldiered the wires, and all done. if you ahe cruise control, i used the 6th gen control. you just have to put it in at an angle. I should do a write up on this. there seems to be alot more happening
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 18, 2010 - 5:12 PM
abraxxa
Joined Nov 27, '05
@Forgmann: awesome! Why can't I order it at my local Mr-T?
cya, abraxxa
post Jan 18, 2010 - 5:33 PM
shegarhuney
Joined Aug 29, '08
From AZ, US
if only you post this earlier.. good job!!.. for all you wanting to do the gen7 (3spoke) steering wheel swaps..
this is it!!.. the missing link!!..
QUOTE (FORGMANN @ Jan 17, 2010 - 1:44 PM) *
post Jan 19, 2010 - 2:48 AM
abraxxa
Joined Nov 27, '05
I just ordered one at Mr-T for about 15euro.
cya, abraxxa
post Jan 19, 2010 - 11:08 AM
GriffGirl
Joined Feb 7, '07
QUOTE (Smaay @ Jan 18, 2010 - 1:01 PM) *
I'm going to do the same, just splice the wires together. The thing above, I'm assuming that's an adaptor? looks great, but I'm fine just splicing them together.
On the CC though, I've got my original one kind of crammed in there, but there's no way to actually bolt the unit in, which bothers me, so I'll also be splicing in the 7th gen CC stalk.
Enter Batman w/instructions on how-to! wink.gif
abraxxa: I'll post up a jpeg of the PDF I took that info from; it's from the BGB, you can find it here on celicatech.com
post Jan 19, 2010 - 11:36 AM
abraxxa
Joined Nov 27, '05
I've got all BGBs as pdfs, which one contains the infos? The 'Electrical Wiring Diagram'?
cya, abraxxa
post Jan 20, 2010 - 5:29 PM
GriffGirl
Joined Feb 7, '07
Yes, it's in the electrical wiring diagram, IIRC search for "SRS" and you'll find it.
post Jan 21, 2010 - 5:38 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE (abraxxa @ Jan 19, 2010 - 5:36 PM) *
In case you are lost we manage meeting and sort it out together smile.gif.
post Jan 21, 2010 - 6:19 AM
abraxxa
Joined Nov 27, '05
Thanks malpaso!
My ST205 is in winter sleep at the moment, will be reactivated at the beginning of march.
I'll swap the wheel as soon as I get the adapter from Mr-T which is in 1-3 weeks.
cya, abraxxa
post Jan 25, 2010 - 4:20 PM
shegarhuney
Joined Aug 29, '08
From AZ, US
hope this helps..
gen7
gen6
post Jan 26, 2011 - 10:24 PM
onggie
Joined Jan 26, '11
From Australia
No point posting up a new thread so I will post here, I recently bought a second hand steering wheel to start on my project car. The only problem is I don't have the harness that actually plugs into the air bag. Pictures can be seen below, was wondering if you have a part number? The steering wheel came from a toyota, and I know a lot of cars share this wheel. Though the connecting harnesses are not the same.
http://static.zooomr.com/images/9666744_b969861c51_b.jpg
http://static.zooomr.com/images/9666746_a4d59039d4.jpg?r=180
I can also take out that little red connector.
I am assuming I need something like on the back of this wheel.
http://i32.photobucket.com/albums/d19/Thenan/AirbagBack.jpg
post Jan 30, 2011 - 12:42 PM
chacha
Joined Dec 29, '05
From So-Cal
yeap...that last picture with the wire is what you need....you are missing that piece and need the adapter that Griff mention so it can connect with the our 6gc wire from the steering column.
post Feb 1, 2011 - 8:03 PM
trdproven
Joined Aug 2, '05
From Guam
I used the adapter as well, for late model celicas, they are the same harness as the 7gc. Its the earlier 94-95 celica that has a different one.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: February 17th, 2025 - 1:11 AM
