> master cylinder., How to
post Jan 11, 2010 - 4:37 PM
my96celica
Joined Jul 15, '07
From High ridge MO
How do I remove and install the master cylinder?
post Jan 11, 2010 - 4:58 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
which one, brake or clutch?
post Jan 11, 2010 - 5:09 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
Brake MC
Clutch
God made man....
Everything else...
Made in China
post Jan 11, 2010 - 7:09 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
removing the reservoir tank isnt neccessary. 2 nuts behind the clutch pedal, remove those, then remove brake fluid lines. Go back under the pedal and remove the locking pin and rod from the clutch pedal. Pull clutch master. Then manually test the clutch push rod and see if fluid comes out (cover eyes or point away from body laugh.gif )
post Jan 13, 2010 - 10:16 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I should have made some how to's when I took everything apart in my car. kindasad.gif kindasad.gif
Lo-Fi Version Time is now: January 11th, 2025 - 2:02 PM
