Security LED Part Number?, Any help is appreciated! |
Jan 12, 2010 - 5:17 AM |
Enthusiast Joined Jul 3, '09 From UT Currently Offline Reputation: 14 (100%) |
Jan 12, 2010 - 5:19 AM |
Enthusiast Joined Jan 5, '09 From Kent, United Kingdom Currently Offline Reputation: 0 (0%) |
I have one going spare!
-------------------- 1996 Green JDM GT4
1998 White JDM SSIII 1994 Black JDM Supra Aerotop 1994 Black JDM GT4 1999 Black UKDM SR 1996 Black UKDM ST |
Jan 12, 2010 - 5:20 AM |
Jan 12, 2010 - 5:51 AM |
im in the uk, so I can find out how much shipping is, it wont be much, but the only numbers printed on it are 489082 and 082-1b23
Jan 12, 2010 - 7:03 AM |
PM'd
Jan 12, 2010 - 12:27 PM |
Enthusiast Joined Nov 21, '05 From Tacoma, WA Currently Offline Reputation: 7 (100%) |
I have part number 81850-12260 written down in my notes but have not actually bought one to put in. That part number came from a 02-05 corolla. They go for around $25 from the dealer or you can get it as part of a cluster on ebay.
Jan 21, 2010 - 4:31 AM |
That part number worked out and cost me $38. Looks kinda odd in the console, but it wired up with my alarm nicely. Thanks RocketScott!
Jan 30, 2010 - 3:54 PM |
I ordered this from ebay for about $30 a little while ago:
Took the security light apart: I ground down a blue led so it is flat like the red one that was in there. Just need to check the voltage that my alarm uses for the led and swap out the resistor. The one I got has a little motion detector also. I need to do some more research to find out how to hook that up. I also need to get a connector for it. The one I found in the catalog isn't comming up at any of the dealers I've checked. |
Jan 30, 2010 - 4:16 PM |
there's a few of these on ebay right now.
http://cgi.ebay.com/ebaymotors/94-99-Celic...=item19b769d2d5 and the system (with indicator) -------------------- |
Jan 30, 2010 - 7:09 PM |
I was about to ask IF you figured out how to use the motion sensor with an aftermarket alarm but since it's you I should really be asking HOW you wired up the motion sensor to work with an aftermarket alarm?
On a side note the sensor has 680 ohm resistor in it, have to go to Radio Shack to get a 560 ohm to get the most out of my blue led. |
Lo-Fi Version | Time is now: November 25th, 2024 - 12:21 AM |
