> Changed ignition wires/spark plug now misfire!!, 7AFE guru's... help!
post Jan 12, 2010 - 10:03 PM
viruz_one
Joined Aug 23, '09
From SL,UT
Today i switched out a few things on my Celica. Including changing oil, changing thermostat, changing spark plugs, and changing ignition wires. After changing everything im getting this really bad missfire. I think maybe I plugged the wire set in the wrong order, or Im missing a vaccum line or something but cant find anything!!
Here's a pic of the engine, see if you guys spot anything. Thanks in advance!..
post Jan 12, 2010 - 10:18 PM
Johnnyny
Joined Apr 28, '09
From York pa
which cylinder is misfiring?
post Jan 12, 2010 - 10:40 PM
viruz_one
Joined Aug 23, '09
From SL,UT
Im not sure, how do i check that?
I unplugged each coil one by one and when i unplugged the the 3rd one (going left to right) it shut off the engine.
post Jan 13, 2010 - 12:30 AM
Stambo
Joined Apr 23, '08
From Muskego,Wi
you probably mess up the firing order of the wires. Unless for some reason the cap or rotor or one of the new wires is going on its way out.
2nd Gen 3s-gte.... It lives!
97celiman
post Jan 13, 2010 - 12:55 AM
Hanyo
Joined Aug 16, '03
From Bay area
you messed up the firing order OR you had a bad wireset.
post Jan 13, 2010 - 1:07 AM
viruz_one
Joined Aug 23, '09
From SL,UT
Thats what im thinking too (firing order.) Does anyone know where i can find the correct firing order, or a diagram?
Im going to get a new cap and rotor tomorrow just to make sure it isnt one of those.
post Jan 13, 2010 - 1:46 AM
CelicaST_CALI
Joined Feb 28, '07
ok you have it wired wrong it looks like...say the cylinders (standing in front of the hood facing the trunk)are 1 2 3 4..switch the wires on 1 and 2...then it should run normal smile.gif
BANNED. for life, you moron.
post Jan 13, 2010 - 1:54 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
pre-gapped plugs or you gapped them yourself??
post Jan 13, 2010 - 2:47 AM
viruz_one
Joined Aug 23, '09
From SL,UT
CelicaST_CALI: Thanks!! Im gonna give that a try as soon as i get home! still at work UGH!!
808celica: I bought some NGKs at autozone. I double checked the gap just to make sure it was ok and they were at .032mm. Which was what they told me was the correct gap.
This post has been edited by viruz_one: Jan 13, 2010 - 2:48 AM
post Jan 13, 2010 - 5:10 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
put back your old wires (should've labeled it before removing) and see if you still get miss fire. since you will be in the distrib why not check the ignition coil resistance with a multimeter and see if you're getting the right power.
This post has been edited by 808celica: Jan 13, 2010 - 5:11 AM
post Jan 13, 2010 - 9:55 PM
CelicaST_CALI
Joined Feb 28, '07
i have a 7afe and checked my order,do wat i said,if the problem remains,do wat 808 said.
post Jan 13, 2010 - 9:59 PM
viruz_one
Joined Aug 23, '09
From SL,UT
Did what CelicaST recommended and it purrrssss now like a kitten. Now i just need to add antifreeze. My temp guage seems to jumping all over the place after the thermostat change. But overall running good! Thanks guys for the help.
post Jan 13, 2010 - 11:52 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
did you bleed out the cooling system?
97celiman
post Jan 14, 2010 - 5:19 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (Stambo @ Jan 13, 2010 - 11:52 PM) *
lol?....
post Dec 2, 2010 - 3:36 PM
deeeggoh
Joined Oct 22, '08
From McAllen Texas
your cap says 1,2,3,4 and your wires say 1,2,3,4...it's not thaaaaat hard
post Dec 2, 2010 - 10:16 PM
TerBeau
Joined Nov 25, '08
From dillsburg pennsylvania united states
you deff got cyl 1 and 2 switched on the cap take the two rear wires and switch them youll be set for sure
those with golf balls golf
those with real balls race
post Dec 5, 2010 - 12:22 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
QUOTE (deeeggoh @ Dec 2, 2010 - 3:36 PM) *
Only if you buy from Toyota will it 1-4 on the wires and cap.
P.S. Not everyone knows how to work on cars, just like you prob. dont know how to do open heart surgery.
Lo-Fi Version Time is now: November 25th, 2024 - 4:55 PM
