> wiring problems, cigaratte wires
post Jan 13, 2010 - 11:56 AM
zfjohnson07
Joined Apr 11, '09
okay so i cut the wires got it all hooked up got a new toggle switch http://www.autozone.com/autozone/catalog/a...randName=Dorman hooke just to be able to use it right. Well for some reason when i turn it on all my lights go dim, and well as you can guess when you turn it off they light back up. Did i do something wrong, i assume i did.. need help asap thank you
post Jan 13, 2010 - 4:54 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
whats the switch for? and also that's not a normal on off switch thats a toggle switch
post Jan 13, 2010 - 6:01 PM
zfjohnson07
Joined Apr 11, '09
the switch is for 4 small led lights already pre strung and everything i have them in my car right now but that switch wont work, whats wrong with the switch what should i get?
post Jan 13, 2010 - 6:50 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
that switch has just read up on different types of switches, im not too sure what toggle switch it is exactly look at that website i showed you and see which one it is and i can help.
Lo-Fi Version Time is now: January 12th, 2025 - 9:44 PM
