> purge cannister on a gt
post Jan 16, 2010 - 9:43 AM
trackdaydavid
Joined Oct 28, '07
From united kingdom
on the st202 celica you have a carbon cannister just next to the fuel filter where does the little small vaccuum pump that pushes onto it go in relation to the engine and also on the biomettallic switching valve on the water hose body just off top hose the sensor has two little vaccuum pipe one of the end and one half way down where do these two pipes go on the engine, i think end one goes to top of throttle body and middle one goes to carbon cannister but engine does run right.
post Jan 17, 2010 - 2:45 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (trackdaydavid @ Jan 16, 2010 - 6:43 AM) *
On the st202 celica, you have a carbon canister right next to the fuel filter. Where does the small vacuum pump go in relation to the engine. Also where does the ported vacuum switch vacuum hose route to? Mine is connected to the top of throttle body and middle one goes to carbon canister but engine does run right.
your basically asking about the vacuum diagram on a st202?
post Jan 17, 2010 - 5:32 AM
trackdaydavid
Joined Oct 28, '07
From united kingdom
doesn't matter sorted it myself and asked the same question several times on this board anyway.
This post has been edited by trackdaydavid: Jan 17, 2010 - 5:32 AM
post Jan 17, 2010 - 4:34 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (trackdaydavid @ Jan 17, 2010 - 5:32 AM) *
laugh.gif good ol' search button..
Lo-Fi Version Time is now: November 29th, 2024 - 10:28 PM
