What's do you idle at? |
Jan 18, 2010 - 6:27 PM |
Enthusiast Joined Sep 27, '09 From Columbus, Ohio Currently Offline Reputation: 3 (100%) |
I think there might be something wrong with my car. It starts up a bit soft and idles around .75 RMP. Last I checked, I was 1.5 RPMs in idle and my start was much stronger.
Let me know if I'm just going nuts. Everyonce in a while it will idle at 1.5, but then soon dips back. It's gone as low as .50 RMP. Thanks. -------------------- |
Jan 18, 2010 - 6:35 PM |
I'm tempted to say that GT's idle higher. I'm at around 800, however, mine also tends to vary sometimes, especially under a lot of electrical load.
'93 MX-5 LE |
Jan 18, 2010 - 6:42 PM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
mines about 1100 RPMS
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Jan 18, 2010 - 7:21 PM |
Enthusiast Joined Jul 23, '09 From Fresno, Ca Currently Offline Reputation: 6 (100%) |
st.. cold start 1.5 normal.. .9 sometimes .7 at the lowest
Jan 18, 2010 - 7:27 PM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
my gt idles at .75_.9 at idle on a cold start.. sometimes it like bogs down for like a slpit secomd to like .45 then it kicks right back to .75_.9 .... i think it does that bc messed around w the throttle cable over the summer to try wat i thought would get a better throttle response for racing ... i found out that the throttly sometimes sticks and revs at 2500 at a redlight lol ... idk if youve messed around w ur cable but that could b it
-------------------- st205 powered ss3 coupe
Jan 18, 2010 - 7:45 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
my idle is at about 1000
-------------------- BANNED. for life, you moron.
Jan 18, 2010 - 10:06 PM |
So I should be fine where I'm at? I just want to make sure I don't need to make an appointment for it to be looked at. I swear it idled higher, but maybe I'm nuts.
Jan 18, 2010 - 10:15 PM |
When the car is warmed up it should be close to 900 RPM. Just shy of 1k.
All regular Celicas I've seen tend start at around 1500 - 2000 when cold and come down to 900 when they warm up. My GT4 though only fast idles at 1100RPM before coming down to 900. -------------------- Mike W
Jan 18, 2010 - 10:24 PM |
When the car is warmed up it should be close to 900 RPM. Just shy of 1k. All regular Celicas I've seen tend start at around 1500 - 2000 when cold and come down to 900 when they warm up. My GT4 though only fast idles at 1100RPM before coming down to 900. Great, thanks for the heads up . -------------------- |
Jan 18, 2010 - 10:35 PM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
5s-gte with 2330 km's on it
1600 cold start, 750 idle |
Jan 18, 2010 - 11:55 PM |
Enthusiast Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
mine cold 1000 then 500 idle
Jan 19, 2010 - 12:56 AM |
Jan 19, 2010 - 1:16 AM |
If that's too low, what's the magic number then?
I mean, how do you know if you have a problem or not. My car isn't stuttering or idleing rough, but at the same time, it's not like it was a month ago. -------------------- |
Jan 19, 2010 - 1:48 AM |
well thats just it, it could be idling fine at 500, but it could be hurting your performance or fuel eco because its so low, lean/rich mixture, or an iac issue. My 5s-fe only had 15,000kms on it and if i let it sit on the 500 rpm line for more than 30 seconds or so, it slowly died
Jan 19, 2010 - 2:07 AM |
well thats just it, it could be idling fine at 500, but it could be hurting your performance or fuel eco because its so low, lean/rich mixture, or an iac issue. My 5s-fe only had 15,000kms on it and if i let it sit on the 500 rpm line for more than 30 seconds or so, it slowly died Would you take it in to be looked at if it usually was around 1000 RPMs but now is 5-700? And that's in cold and heat. Seriously, when I start the car, it sounds week.. it doesn't make the h h h humMMMmmmm sound when starting up now. It's just h h h hhmm with a low dip in the middle of the hhmm. Btw, this all changed the day the new battery terminals were installed. They are not corroded though, or melting off like my old cheap ones from auto zone. The dealer put these ones on (they're stock), because I was tired of facing issues with 3rd party ones. This post has been edited by CastrolCelica: Jan 19, 2010 - 2:09 AM -------------------- |
Jan 19, 2010 - 11:11 AM |
Enthusiast Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
In cold my celica starts with a high rev to 2000 (for a millisecond) then it idles at 1000. Once warm it's between 750~500.
Dunno but that's what it does... -------------------- Has no more Celicas
Jan 19, 2010 - 12:24 PM |
Well today was much better. She idled cold at 1.5 and idled consistently at .9
Maybe she was just having an off week. -------------------- |
Jan 20, 2010 - 1:38 PM |
okay my car might idle at 2000 cold and then 1000 warm i swear the other week it was 500 and its never acted up or anything
Lo-Fi Version | Time is now: January 15th, 2025 - 11:56 AM |
