WTB: Rear driver side quarter window for Coupe, Need ASAP |
Jan 19, 2010 - 12:14 AM |
Enthusiast Joined Sep 23, '08 From Hawaii Currently Offline Reputation: 10 (100%) |
This is what just happened
i am in need of a rear driver side quarter glass window for a coupe preferably with the trim but without would be fine as well. please let me know what you have and how much you want for it. Thanks, -Joel This post has been edited by captb: Jan 19, 2010 - 12:41 AM |
Jan 19, 2010 - 11:36 AM |
Enthusiast Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
if you can tell me how to safely remove it, I can try to have mine removed tomorrow.
-------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Jan 19, 2010 - 3:58 PM |
well there is alot of sealant holding it in place, im pretty sure with a good amount of heat from inside the car it should come off easily with a little bit of force. once you remove the interior plastic there is only the the window and metal so i dont think you will burn anything. if you have access to a heat gun could you try removing it for me. also, how would you want for it. Thanks.
Jan 19, 2010 - 4:04 PM |
well there is alot of sealant holding it in place, im pretty sure with a good amount of heat from inside the car it should come off easily with a little bit of force. once you remove the interior plastic there is only the the window and metal so i dont think you will burn anything. if you have access to a heat gun could you try removing it for me. also, how would you want for it. Thanks. you could try a hair dryer too but it may take a bit longer. |
Jan 19, 2010 - 5:31 PM |
if you can tell me how to safely remove it, I can try to have mine removed tomorrow. you can hold off on it for now. i found a '90 celica coupe locally that looks like it will fit. im gonna check it out tomorrow but if it doesnt fit ill let you know. Thanks again. |
Jan 19, 2010 - 9:03 PM |
lol. ok
Feb 23, 2010 - 1:50 AM |
bump. first efforts didnt go so well, still looking for a replacement window.
Lo-Fi Version | Time is now: November 26th, 2024 - 6:57 PM |
