> Idle driving me crazy!! Won't come down., What's wrong?
post Jan 19, 2010 - 3:41 PM
Temporary-Failur...
Joined May 27, '09
From Finland
I have -94 ST202 with 3SGE engine. Idle won't come down. It idles with warm engine around 1100rpm. I have checked almost everything:
1. vac leaks
- can't find any
2. cleaning IAC
- cleaned
3. error codes
- nothing
4. throttle cable too tight
- no no and no...
5. adjusting IAC
- Adjusted and no help
6. checking IAC does it even work
- checked, it works
7. selling the car and buy Nissan instead
- probably...
Can broken lambda sensor cause this?
post Jan 19, 2010 - 3:55 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
QUOTE (Temporary-Failure @ Jan 19, 2010 - 2:41 PM) *
1. vac leaks
- can't find any
2. cleaning IAC
- cleaned
3. error codes
- nothing
- no no and no...
5. adjusting IAC
- checked, it works
- probably...
reset the ecu, follow the "how to:"
wAkE uP, u'Ll sLeEp WhEn U DiE.....
post Jan 19, 2010 - 4:04 PM
blu94gt
Joined Mar 23, '05
From Kansas City
I don't know how to check it on our cars, but the a/c has a setting to increase the idle. If you've had the a/c or defroster on, it will idle high.
The same circuit that will increase the idle can also be faulty, causing the car to idle slightly higher even without the system on.
1999 Celica GT
post Jan 19, 2010 - 4:07 PM
Temporary-Failur...
Joined May 27, '09
From Finland
I have no a/c.
Resetting ecu is just unplugging battery for an hour and put back and that's it? Done that...
post Jan 19, 2010 - 4:19 PM
azian_advanced
Joined Apr 18, '05
From Calgary
have you checked if the thermistor for the water temperature sensor is working? or putting out the right voltage? it might be thinking it's cold all the time.
post Jan 19, 2010 - 4:23 PM
manphibian
Joined Oct 13, '06
From UK
j/k, that's a good call, i had that problem once on my 3S-GE....
post Jan 20, 2010 - 12:36 PM
Temporary-Failur...
Joined May 27, '09
From Finland
QUOTE (azian_advanced @ Jan 19, 2010 - 4:19 PM) *
Well well... Earlier I wrote that "error codes nothing" but I just wrote how local garage said when thay tried to find reason for that. But I checked myself errors and found something.
BLING BLING.......BLING BLING
.....silence....
etc...
Temperature sensor!! I'll get a new one and see how it goes. I hope that this is only Temporary-Failure.
This post has been edited by Temporary-Failure: Jan 20, 2010 - 12:37 PM
post Jan 22, 2010 - 11:11 AM
Temporary-Failur...
Joined May 27, '09
From Finland
I replaced sensor, reset ECU and no help. Still 1100RPM.
I checked fault codes and now engine light blinks quite fast and continuously.
edit:
I think I found the solution. I adjusted posture of the TPS and....... WORKSSS!!!!!!!!!! Now idle drops nicely to its target rpm.
But because I'm pessimist, I just think that I fixed problem by making other problems and real problem still occures altought it is not visible just now.
edit2:
What kind of mayhem car should run after resetting ecu? Before founding solution I resetted ecu many times. Car did nothing differently after that. It was basically normal start. But now after adjusting TPS, first start was very odd. Idle was jumping 200-300rpm somewhere 2000rpm very fast. It did that less than half minute and settled down. I gave a little bit gas and it started to jump around 1000rpm few times and then dropped idle to the normal. Same thing occured few times when I was doing test run. Maybe 10 minutes it acted strangely and now it works perfectly.
This post has been edited by Temporary-Failure: Jan 23, 2010 - 3:16 AM
post Jan 25, 2010 - 4:04 AM
trdproven
Joined Aug 2, '05
From Guam
timing?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: April 23rd, 2025 - 5:48 PM
