dumb question, OBD2? |
Jan 20, 2010 - 5:22 PM |
Enthusiast Joined Oct 23, '09 From boston Currently Offline Reputation: 0 (0%) |
is the 1996 toyota celica (non-turbo) an OBD2? and if it is where is the slot?
Thanks, dumb question but yea, we all have them. ahah |
Jan 20, 2010 - 5:25 PM |
Enthusiast Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
driver side fender under the hood, where the firewall meets the fender.
Jan 20, 2010 - 5:29 PM |
Thank you, im used to them being inside the car hahah.
Jan 20, 2010 - 5:31 PM |
Enthusiast Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) |
should be under the dash on the gas pedal side
Jan 20, 2010 - 6:31 PM |
is it OBD2? i saw the one under the hood on the driver side fender, but the OBD2 that im borrowing does not fit... im also goign to check under teh diverside dash by the gas.
Jan 20, 2010 - 7:19 PM |
Enthusiast Joined Jul 23, '09 From Fresno, Ca Currently Offline Reputation: 6 (100%) |
Jan 21, 2010 - 2:05 AM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
My diag computer has 4 or 5 different OBD2 cables, there is also a connector under the dash by the steering column.
Jan 21, 2010 - 2:16 AM |
diagnostic is under the hood, ecu obd2 connector is to the right of the steering column right above the gas pedal pretty much
Jan 21, 2010 - 8:38 AM |
Enthusiast Joined Jan 16, '07 From covington, KY Currently Offline Reputation: 9 (77%) |
is it OBD2? i saw the one under the hood on the driver side fender, but the OBD2 that im borrowing does not fit... im also goign to check under teh diverside dash by the gas. 95 OBDI and 96 + ODBII. thats for sure.. Thats a yes and a no in 1996 they required that all cars have OBDII but not all 96 car where built in 96 many where built in 95 before the requirement. So when working on a 96 always check the date on the door jam sticker to know if it is OBDI or II |
Jan 21, 2010 - 6:38 PM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
Thats a yes and a no in 1996 they required that all cars have OBDII but not all 96 car where built in 96 many where built in 95 before the requirement. So when working on a 96 always check the date on the door jam sticker to know if it is OBDI or II Also depends on the intended territory. IIRC, OBDII was standard fit on the USDB 96+ and JDM 98+. UK/Europe didn't get OBDII in 6th Gen. at all. -------------------- Davey
Items for sale |
Jan 21, 2010 - 10:37 PM |
^ Along with that many cars -96 can be OBDII in the United States.
Jan 22, 2010 - 2:10 PM |
is it OBD2? i saw the one under the hood on the driver side fender, but the OBD2 that im borrowing does not fit... im also goign to check under teh diverside dash by the gas. 95 OBDI and 96 + ODBII. thats for sure.. Thats a yes and a no in 1996 they required that all cars have OBDII but not all 96 car where built in 96 many where built in 95 before the requirement. So when working on a 96 always check the date on the door jam sticker to know if it is OBDI or II yeah thats true.. If they were made real early in the year right? but then , does that mean even tho its 96, its not 25th anni? |
Jan 25, 2010 - 3:15 AM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
OBD II ports will ALWAYS be inside the car, and use the same type of connector. Part of the standard is that the port will be inside the car, within reach of the driver.
-------------------- 1999 Celica GT
Jan 25, 2010 - 3:39 AM |
Enthusiast Joined Nov 7, '09 From Victoria BC Currently Offline Reputation: 0 (0%) |
Where does the OBD2 port's wires goto exactly?
I had a look at the 6th gen BGB (I think it was?) but it was dated for pre-OBD2 I believe. -------------------- |
Jan 28, 2010 - 8:29 AM |
Where does the OBD2 port's wires goto exactly? I had a look at the 6th gen BGB (I think it was?) but it was dated for pre-OBD2 I believe. The OBDII(On Board Diagnostics version2) goes to the PCM(Powertrain Control Module) also known as the ECU or the cars computer. |
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:45 AM |
