> Best oil for the 7A-FE? And mixing oil?
post Jan 21, 2010 - 6:18 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
I'd like to know what's the recommended oil for my 7A-FE because I'm getting ready to change it for the first time since I got the car a couple months ago. Also, is it safe to mix oil?
June '12 COTM
'95 AT200
post Jan 21, 2010 - 7:25 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
QUOTE (HectortheRican @ Jan 21, 2010 - 6:18 PM) *
personaly i like the castrol gtx high mileage, i was burning a quart of oil every week using conventional, but now its a quart maybe every 6 months lol, not sure about mixing though
2001 Solar yellow Lexus IS300
post Jan 21, 2010 - 7:26 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
the cap on mine says 10w-30, but i run 5w-30 with no apparent problems. mixing what? weights? brands? types?
post Jan 21, 2010 - 7:55 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Bitter @ Jan 21, 2010 - 6:26 PM) *
By mixing I mean just oil in general. Because I don't know what kind of oil the guy who had it before me used, and it doesn't actually NEED an oil change at the moment, so I was wondering whether I'd have to change the oil anyway so it would be all the same oil or if I can just get a quart and add some oil in until it's time to change it
June '12 COTM
'95 AT200
post Jan 21, 2010 - 8:06 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
You really should have no problem with mixing oil. Its not like mixing two different brands will cause your engine to seize and explode.
post Jan 21, 2010 - 8:17 PM
CelicaST_CALI
Joined Feb 28, '07
BANNED. for life, you moron.
post Jan 21, 2010 - 8:50 PM
HectortheRican
Joined Dec 26, '09
QUOTE (CelicaST_CALI @ Jan 21, 2010 - 7:17 PM) *
Do you run it all year round?
QUOTE (Spider77 @ Jan 21, 2010 - 7:06 PM) *
Thanks man, that's all I needed. Now to find the right oil..
June '12 COTM
'95 AT200
post Jan 22, 2010 - 12:34 AM
zonz540
Joined Jul 3, '09
From UT
10w-30 Mobil1 Full Synthetic for High Mileage... Mobil1 was burning through my engine too fast, different viscosity slowed it down significantly.
post Jan 22, 2010 - 12:38 AM
HectortheRican
Joined Dec 26, '09
QUOTE (zonz540 @ Jan 21, 2010 - 11:34 PM) *
That's actually the oil that I just went and bought. Good choice?
June '12 COTM
'95 AT200
post Jan 22, 2010 - 1:35 AM
CelicaST_CALI
Joined Feb 28, '07
yea i run it 365....im in cali so the weather isnt to bad..goes from about 20-105 degrees hahaha
post Jan 22, 2010 - 2:00 AM
zonz540
Joined Jul 3, '09
From UT
Im in Utah and the weather here goes from hot to cold. 10w-30 has the best range for where im at. I run it year round. If you live down where it never gets below 50 degrees, 5w-30 might work the same/better. Its lower viscosity and might burn up faster if youve got high mileage, though.
post Jan 22, 2010 - 4:11 AM
Espo
Joined Aug 11, '09
From Buffalo, NY
I think I'll switch to 10w-30 then...been using 5w and it eats up a quart every 3000.
Also, we are talking about 7a-fe engines right? Or does it matter? I've never had a GT so I don't know.
post Jan 22, 2010 - 10:04 AM
HectortheRican
Joined Dec 26, '09
Yeah it's about 7AFE. It goes from about 15 at the worst to 105 at the worst in TX, so I think I'll be good with 10W-30
June '12 COTM
'95 AT200
post Jan 23, 2010 - 12:46 AM
zonz540
Joined Jul 3, '09
From UT
The High Mileage stuff preserves the weight of the oil and ups the viscosity. Its a bit thicker and it wont seep through your engine and out your exhaust as much... Keeps it in the pan longer.
post Jan 25, 2010 - 4:03 AM
trdproven
Joined Aug 2, '05
From Guam
royal purple FTW
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 25, 2010 - 9:05 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (HectortheRican @ Jan 21, 2010 - 6:55 PM) *
First thing you should ALWAYS to when you buy a car, do all regular maint. plugs, wires, cap rotor, oil/filter...
i use 5-30 Mobil1 full synth in my 7A and it does well year round
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 11th, 2025 - 10:01 AM
