> FS: Misc 6th gen bits, need to sell asap!
post Jan 22, 2010 - 3:22 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
I have some stuff sitting around from my car that I don't need.
First up is an Injen Short Ram Intake minus heat shield. Retails for $230-$250 (shipped) depending on where you go. SOLD!. I will include the license plate frame with it as well assuming I can find it.
Next up is a passenger high beam. Great condition with no broken tabs. Asking $40 + shipping.
Now we have a brand new, unused pair of 60MM premium Prosport Gauges. One is oil pressure and the other is water temp. Both gauges light up Amber/White depending on how you want to wire them up. I can sell the oil pressure for $115 shipped and the water temp for $80 shipped or both for $180 shipped. I am open to offers though on these. The boost gauge in the pictures has been sold already.
Next is a set of 6.5" Boston Acoustic S60 Component speakers. They're a great entry level components and blow the stock speakers out of the water assuming yours still work. lol RMS is 65w and peak is 200w. Don't let the specs fool you. They sound great even when not hook-up to an aftermarket amp. They are pre-mounted into the stock speaker housing, so they'll be a simple plug and play. Asking $100 + shipping within the continental US.
Here we have a Denso MK4 Supra Fuel Pump with what i was told had about 40K-60K miles on it. Includes new OEM fuel sock. Asking $100 shipped Friend of mine thought it would be haha funny to open the packaging to the fuel sock.
Next up is door panels from my Coupe. They're in pretty good condition with some minor scuffs. Asking $80 + shipping for them.
Here's a firewall brace from my Coupe. pretty simple and straight forward. asking $40 + shipping
Next is a used radiator with about 2000 miles on it give or take. Can be used with Auto or Manual tranny. I'm not sure if it can be used with a 7A though. Asking $100 + shipping for it.
Here we have a pair of used front rotors with plenty of meat on them. Surface rust should disappear once some miles are put on them again. Asking $50 + shipping for them
That's about all I have for now until I can dig up other stuff from storage and then finally muscle off my rear suspension, so keep an eye out for KYB GR-2 struts and Eibach springs when I get them off. smile.gif
This post has been edited by NgoFcukinWay: Feb 15, 2010 - 10:23 PM
-Alex {](O_o)[}
post Jan 22, 2010 - 3:39 PM
SlvrCelica09
Joined Jan 10, '09
From Burtonsville, Maryland
dibs on panel and strut bar
This post has been edited by SlvrCelica09: Jan 22, 2010 - 3:39 PM
THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma..
6gc.net's outlaw vigilante because im a LEADER not a follower.
post Jan 22, 2010 - 4:56 PM
Bigblock
Joined Feb 14, '09
From Mid West
Passenger side hi-beam for left hand drive?
Price to 61364??
Thanks
post Jan 24, 2010 - 3:30 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE (SlvrCelica09 @ Jan 22, 2010 - 3:39 PM) *
If you're serious about it, let me know so I can find a box for them to have them ready.
Headlight pending payment.
-Alex {](O_o)[}
post Jan 24, 2010 - 1:29 PM
dabazied
Joined Jun 10, '07
From Riverside, CA
QUOTE (NgoFcukinWay @ Jan 22, 2010 - 12:22 PM) *
So you still have the two gauges left correct? Speakers are still unsold as well? Are those pre mounted for the doors or the rear panels.
And lastly, the radiator WILL work for the 7a, just have to get a little thoughtful on what radiator hoses you buy for it(I have the gt one installed in my st, works fine and has for the last 3yrs)
She's Alive...... Again!!!
Sweet Jesus.
You rang?
Sorry, wrong number. :laugh:
post Jan 24, 2010 - 3:34 PM
Bigblock
Joined Feb 14, '09
From Mid West
LMK...(head light) sells or if I can get it.
Thanks
post Jan 25, 2010 - 12:55 AM
SpadeBF
Joined Mar 29, '09
From Detroit,MI
Is that a spectre radiator? (not same company as the intake brand, regardless)
Looks just like my rad i bought when i need to replace mine
post Jan 25, 2010 - 12:56 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Yes, I still do have the Oil Pressure and Water temp gauges left. The speakers are mounted into the pods for the front door and to fit the tweets into the covers, i wrapped them in electrical tape, popped the mesh covering from the covers, and wedged the tweeters in place. The mounts they came with wouldn't angle the tweeters correctly, so that's what i did to remedy the problem. Hardly noticeable unless you're really looking for it.
I'm not sure about brand on the radiator, but I'll check to see if there are any kind of marking on it later today to see if there are any designations.
I have more parts up for grabs and those will be posted up hopefully by tonight.
-Alex {](O_o)[}
post Jan 28, 2010 - 1:11 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Passenger high beam sold!
Some more tidbits! Most parts have about 200K miles on them but have never let me down. ALL PRICES DO NOT INCLUDE SHIPPING AND ARE FINAL!!
THE $20 BIN
Automatic Brake pedal
OEM Steering column panel thing with dimmer switch
THE $30 BIN
OEM Amp
Cruise Control ECU
THE $40 BIN
Manual 5S-FE alternator
Manual 5S-FE ECU
Shifter bezel with pocket
Airbag ECU and Brake Master Cylinder w/ABS
Brake Booster
Front Windshield Wiper Motor
'94-'95 (Pre-facelift) turn signals
USDM Coupe/Vert tail lights with harness. They have some minor cracks and condensation does build up from time to time, but nothing major.
THE $XX BIN
Front 5S-FE Motor Mount. Looks to be in very good condition. $75 + Shipping
Complete 5S-FE wiring harness. Ideal for those doing a 3S swap and don't want to pull their running 5S just yet to get a harness done. The only little problem with them are the wires by the ECU where I had my S-AFC2 wired in. There are some pigtails left to wire it all back up to normal. $100 + shipping
Doors. Each door will come with locking mechanisms, window motors, and pretty much whatever's pictured aside from mirrors. Each door has been dynamatted as you can see. Gives the doors a nice solid *thud* when closing them and helps with sound for speakers. Only problem with the driver's side door is that the lock/door handle has been smashed due to a break in. Other than that, the doors could use a bit of cleaning to look wonderful again. Great for those with rusting doors! $100 + shipping EACH
hopefully that's everything and I haven't forgotten anything else. If there's anything else you guys need, just let me know.
This post has been edited by NgoFcukinWay: Feb 9, 2010 - 11:17 PM
-Alex {](O_o)[}
post Jan 29, 2010 - 1:58 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
I forgot I had pics of this and didn't post.
OEM Windshield washer fluid reservoir. $40 + shipping.
-Alex {](O_o)[}
post Jan 29, 2010 - 11:23 AM
Skinerp89
Joined Aug 12, '08
From Maryland
pmd about intake and maybe some other things >.< your gonna make me even more broke then i am
post Feb 8, 2010 - 10:28 PM
captb
Joined Sep 23, '08
From Hawaii
yo, ur inbox is full.
anyways, sorry for bugging but i really need the window. were you able to pull it over the weekend? pls give me some good news. =P
post Feb 9, 2010 - 11:11 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Cleared out my box and sent you a PM.
SRI is pending sale. head light is sold as is the ECU and fuel pump.
Another item up for bid is a leather wrapped JDM 3-spoke non-airbag steering wheel. It's a bit dirty, so I'll try to clean it up prior to the sale. The leather at the top has a bit of wear in it, but doesn't prevent it from being functional.
Asking for $150 + shipping for the wheel.
-Alex {](O_o)[}
post Feb 11, 2010 - 1:21 PM
Skinerp89
Joined Aug 12, '08
From Maryland
payment sent for SRI
post Feb 15, 2010 - 10:24 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE (Skinerp89 @ Feb 11, 2010 - 2:21 PM) *
Payment received and tracking number sent!
BUMP! Steering wheel is OBO btw!
-Alex {](O_o)[}
post Feb 19, 2010 - 11:12 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
bump
-Alex {](O_o)[}
post Mar 9, 2010 - 12:44 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Bump! Steering wheel is sold!
Any offers on anything? If someone buys the components for my asking price, I'll throw in the OEM tweeter covers for free, otherwise, tweeter covers will go for $36 shipped.
-Alex {](O_o)[}
post Mar 9, 2010 - 11:22 AM
Seztor
Joined Mar 23, '08
From Denmark
Hey mate
I might be interested in the speakers
Is it 100$ for 2 two speakers mate? How old are they?
[font=CELICA FOREVER][/font]
post Mar 9, 2010 - 1:10 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE (Seztor @ Mar 9, 2010 - 12:22 PM) *
Hey mate
$100 + shipping for 2 woofers, 2 tweeters, 2 crossovers, and the 2 tweeter covers if you want those. I bought'em in November of '06, so they're about 3.5 years old. Age hasn't affected them and they still sound great before I took them off.
-Alex {](O_o)[}
post Mar 9, 2010 - 4:06 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Do you have the bettery tie downs ? The metal that holds the battery secure ? If so PM me I want them and I'm looking for the rubber O's for the headlights and the little shifter thing with the cogetette lighter I'm intrested in all those so please PM me of you have any
Lo-Fi Version Time is now: November 25th, 2024 - 11:32 PM
