Wet footwell (drivers) st205, Can't figure this one out. |
Jan 23, 2010 - 3:53 AM |
Enthusiast Joined Jan 22, '10 From Blackpool, UK Currently Offline Reputation: 0 (0%) |
Hey guys, finally got myself back into the celica game after a few years out and bought myself a st205 WRC
I'll get pics up soon, can't do it on my phone. However having a tiny teething trouble that someone may be able to help me with. When I got home With the car after buying it I went to put new mats in and realised thedrivers footwell and the rear passengers footwell, again on the drivers side was literally soaking. Few days later I jet washed the car and the day after it was noticeably more wet. So it's obviously got a leak somewhere. Anyone got any ideas? Thanks in advance for any help |
Jan 23, 2010 - 4:19 AM |
Enthusiast Joined Jul 2, '08 From SoCal Currently Offline Reputation: 6 (100%) |
does it have a sunroof? may be a loose drain hose thats leaking into the passenger compartment.
Jan 23, 2010 - 9:40 AM |
Enthusiast Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
I forgot where... but I think its from the a pillar then dripping down there.
IIRC... theres a thread on here somewhere. |
Jan 23, 2010 - 5:23 PM |
Enthusiast Joined Aug 25, '08 From England Currently Offline Reputation: 1 (100%) |
Heater matrix leak.
Jan 23, 2010 - 5:25 PM |
if you have a sunroof you need to check the drains. They are in the Apillar and the C pillars (you'll have to start removing some of your interior for this) and make sure the tubes are clear.
Jan 23, 2010 - 6:55 PM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
do you have splash guards installed?
-------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 23, 2010 - 6:33 PM |
Hey guys, bit of an update on this one, found the main source of the leak in to the rear drivers side footwell, small bit of welding and undercoat and thats sorted, dry as a bone now.
However the drivers footwell is still pretty sodden ive found out today, havnt noticed as it hasnt been raining and ive had mats over it... I believe there is some sort of rubber grommet or bung in the offside wheel arch, could this have come loose causing water to seep in? |
Mar 25, 2010 - 11:58 PM |
Enthusiast Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
the grommets are for draining water out...usually at the lowest point so water seeping in there should not happen unless you are submerged
-------------------- ST205 Crew represent
Challenge Accepted |
Mar 27, 2010 - 10:39 PM |
Enthusiast Joined Sep 12, '05 From Who says you can't circle race a celica? Currently Offline Reputation: 5 (100%) |
Check the front vents where the a/c heater feed is in the cowl (light where the wipers are). The corners in MR2's tend to rot out and then leak into the footwells.
-------------------- 94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief |
Lo-Fi Version | Time is now: November 27th, 2024 - 6:25 AM |
