noisy rattle, cause?? |
Nov 5, 2003 - 4:31 PM |
Enthusiast Joined Apr 18, '03 From milwaukee, wisconsin Currently Offline Reputation: 0 (0%) |
ok another problem so everytime i go over a little bumb my car makes that nosie that maby the spare isn't tightened enough or something similar. well i set off to tighten it down and found out that the wheel was put on wrong last time it was used so i tightened it and thought hey great now i can drive without that noise anymore but i dont think helped much because i can still hear that clunking sound evertime i go over a bumb, big or small. Anyone else have this problem as well?? solutions??
Nov 5, 2003 - 5:40 PM |
Enthusiast Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
Check the jack hidden in the trunk on the right side inside the hidden compartment, expand the jack into its holder spot I had the same problem
Nov 5, 2003 - 7:50 PM |
Enthusiast Joined Sep 4, '03 From Twin Cities MN Currently Offline Reputation: 2 (100%) |
yeah i have this same problem too! its so annoying- and ive removed my spare and my jack- not these... Ive been told it might be a sway bar bushing thats worn out, but im not positive on this. Yeah if anybody does know what this is it would be GREATLY appreciated if you could tell us how to fix this...
-------------------- Car #3: 98 Accord LX- purchased 5/06, totaled 8/06
Car #2: 95 Celica GT- purchased 8/03, current daily driver Car #1: 01 Focus ZX3- purchased 5/01, sold 8/03 |
Nov 5, 2003 - 9:46 PM |
Enthusiast Joined Jul 31, '03 From GA Currently Offline Reputation: 0 (0%) |
have you modded your suspension in anyway? often times the sway bar linkages get stripped and can't be tightened all the way. this caueses play which results in rattle. this wouldn't happen more than likely unless you had unscrewed that at any point.
cormudgen |
Nov 6, 2003 - 3:23 PM |
well i checked and its not the tire anymore and the jack is very secure inside its compartment and i havent done anything to lower car either due to snow and what not so now i really dont know what it could be but that sound only affects me when others are in the car and i have the music turned down so they dont complain about how loud it is. but ya ill keep looking for things that might cause the problem.
Nov 13, 2003 - 6:57 PM |
Enthusiast Joined Nov 3, '02 From mass Currently Offline Reputation: 0 (0%) |
i;ve got the same problem!any help would be greatly appreciated
Nov 13, 2003 - 7:09 PM |
Enthusiast Joined Sep 30, '02 From NS Can Currently Offline Reputation: 0 (0%) |
I'm gonna ave to say swar bar bushings. I had the EXACT same problem til I fixxed mine. not hard to do LOL lie 4 bolts. DOes it almost sound like you read shock is toppingout if so definitly sway bar bushings.
Nov 14, 2003 - 1:37 PM |
Enthusiast Joined Feb 3, '03 From Maryland Currently Offline Reputation: 0 (0%) |
I have the same problem, a loud annoying rattle
i checked my jack and it wasnt that and im sure its not the spare it sounds like its coming from the back but kinda high, like theres marbles in the trunk or in the plastic peice surrounding the rear speakjers or something |
Nov 15, 2003 - 3:03 AM |
Enthusiast Joined Apr 19, '03 From Washington Currently Offline Reputation: 0 (0%) |
ok, i have a rattle...and i know it's my tranny. i know cause i got out of my car and had a friend rev it through all the gears and then neutral. conclusion: does it in neutral and 5th gear....don't know which part of the tranny it is...but i'll figure that out when i do my swap
Lo-Fi Version | Time is now: November 24th, 2024 - 8:32 AM |
