> PLEASE help fuel problem
post Jan 25, 2010 - 6:58 PM
madmike91
Joined Jul 26, '07
From akron,oh
have a 7afe and it wouldnt start the other day i check to fuel pump it was good. I changed the fuel filter and it took awhile to start it. Finally, started lets it run for 30mins went and put gas in it. Once i left the gas station it died. now when i start it it take forever and shakes bad. cant hit the gas or it dies out. also smoking from to back of the intake manifold. please helpppppp
post Jan 25, 2010 - 8:15 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
the engine is smoking? you get some really bad/cheap fuel? Nothing in the intake manifold should catch fire... there is no ignition source. If there is infact smoke inside the intake manifold you have a number of potention problems:
1. The valve seals are so worn you've lost most of your compression and igniting gas within the manifold
2. your injectors may be fried
3. If you are detonating in the cylinders your causing overheating/head damage, and your Head gasket might be on its way out.
Now if you give it gas and it dies as you stated, its not getting enough fuel, I don't no how cheap you are with gas (Im not trying to be a dick) but if you run 87 octane out of a hick gas station with a rusty old tank there is a chance the filter in the tank (the pickup has a filter) or the pump (in the tank as well accessable thru the carpet in the back seats) is going. But more probable, would be your fuel pressure regulator (FPR) if the pressure is too low and u give it gas you will stall.
Lots to look for bro, need more info
post Jan 25, 2010 - 8:21 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE (madmike91 @ Jan 25, 2010 - 6:58 PM) *
the intake manifold is smoking? black or dark grey smoke?
First thought is that something is restricting your exhaust badly. possibly a clogged exhaust? (piss anyone off lately that'd put a banana in your tail pipe? lol) but there are other things that can do this too.
how many miles you have on this thing?
when's the last time you did work to your ignition system? (EG new plugs, wires, distributor ect.)
This post has been edited by D-Man: Jan 25, 2010 - 8:23 PM
Damn D-Man - most impressive.
post Jan 25, 2010 - 9:43 PM
madmike91
Joined Jul 26, '07
From akron,oh
its gray smoke and it has around 175000 and i check the cap wire inginition and everything it seems like its not getting gas you thing it could be the egr
Lo-Fi Version Time is now: January 11th, 2025 - 10:47 AM
