> 3rd gen 3sgte, 3rd gen 3sgte in the st205 use the same parts as
post Jan 25, 2010 - 10:06 PM
celica95-95
Joined Aug 4, '06
From Toronto
hey
would water pump, timing belt, spark wires , headers ...ect would these parts all be the same with in the 3sgte faimly?
post Jan 25, 2010 - 11:05 PM
Culpable04
Joined Apr 17, '06
From New Jersey
water pump
get a 2nd gen water pump without the cover, and swap the water pump cover from your old one. the inner part is exactly the same, but the cover is different, when you order the pump without the cover it'll come with the needed gaskets
timing belt
ideally you want a 3rd gen timing belt, but second gen works, it's just 1 tooth shorter when compare to a 3rd gen, a lot of guys have been running on 2nd gen belts and it works perfectly fine.
sparkplug wires, same as 2nd gen
headers ( exhaust manifold )
use the OEM, but if you have to go aftermarket, the ones made for the second gen will work as far as I know, but I'm not 100% sure of this. so double check before spending the money.
post Jan 25, 2010 - 11:27 PM
celica95-95
Joined Aug 4, '06
From Toronto
Thanks bro
post Jan 25, 2010 - 11:36 PM
celica95-95
Joined Aug 4, '06
From Toronto
if the wires and dib, sparks and the same then i ' am taking that the rotor clip would be as well?
post Jan 26, 2010 - 8:28 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (celica95-95 @ Jan 25, 2010 - 11:36 PM) *
in english please?
also i believe 2nd and 3rd gen exhuast manis have different bolt patterns
This post has been edited by pittfirefighter: Jan 26, 2010 - 8:29 PM
Breaking Axles...
post Jan 26, 2010 - 8:31 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I'm guessing he said
If spark plug wires, distributor ad spark plugs are the same then I'm taking that rotor would be the same as well ?
and yes, rotor is the same
QUOTE (pittfirefighter @ Jan 26, 2010 - 8:28 PM) *
in english please?
they may have, I haven't had both side by side to compare, thus why I ask him to double check lol.
thanks for clarifying
post Jan 27, 2010 - 6:04 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
2nd gen 3SGTE exhaust manifold will not bolt on a 3rd gen 3SGTE head and vice versa. They share different bolt pattern and exhaust port spacing.
For the spark plug wire, Toyota has different part number for the spark plug wire set between 3SGTE generations. Even 90-91 and 92-93 spark plug wires are different. Search more about these, do not buy them too fast.
Sam
Lo-Fi Version Time is now: February 17th, 2025 - 6:47 PM
