Intercooler St205 help, Are there 2 rad and front one and smaller one? |
Jan 25, 2010 - 11:33 PM |
Enthusiast Joined Aug 4, '06 From Toronto Currently Offline Reputation: 0 (0%) |
Just about to do a swap of 3rd gen 3sgte in to 5sfe with a gt4 front end , will the stock rad fit in and work with the 3sgte 3rd gen ?
and is the intercooler on 3sgte have two rad's ... i seen in some pic's a smaller looking rad maybe a (Front Mount Heat exchanger) I this part need in the swap ?? |
Jan 26, 2010 - 12:00 PM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
the st205 intercooler is a Water to Air intercooler it sits on top of the engine. (the large box u see)
as for the 2 radiators, 1 is the radiator while the other is the heat exchanger. And YES the heat exchanger is required for the swap. -------------------- Kawi Love |
Jan 26, 2010 - 12:59 PM |
As long as you have a gt, the stock radiator will work fine. ST's need to be modified a bit.
And yes, the bottom one is the heat exchanger for the stock intercooler. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 26, 2010 - 1:09 PM |
Yea I have a gt , would I still need a heart exchange for the swap ?
Jan 26, 2010 - 1:10 PM |
Yea I have a gt , would I still need a heart exchange for the swap ? YES (if you plan on using the stock water to air intercooler) NO (if you plan on using an air to air front mount intercooler) -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 26, 2010 - 1:25 PM |
On most Motor it seem that the hear exchange does not come with ?
does it bolt up to the other side of the rad? This post has been edited by celica95-95: Jan 26, 2010 - 10:10 PM |
Lo-Fi Version | Time is now: November 24th, 2024 - 10:01 PM |
