> Great News, sway bar end linkages
post Nov 5, 2003 - 8:45 PM
Cormudgen
Joined Jul 31, '03
From GA
Great news for everyone that has had a problem with a stripped sway bar end linkage. I happened to be at Discount Auto Parts earlier and figured I'd go ahed and ask him if he could orde some Sway bar end linkages. He says "nop, but i've got em in stock". Anyways they are only $23.99 a side! I know my Toyota wanted $50 a side and I've heard of other dealeships chaging as much as $75-100 per side. I went ahead and got them so hopefully I will be able to put them on this weekend!
i'll let you konw how it goes.
cormudgen
post Nov 5, 2003 - 8:48 PM
LatinKraze
Joined Oct 22, '03
SHIRT!!! i dont even know what that is. im still in my car knowledge infancy. So what is a sway bar? Dumb question, i know. Feel free to commence flamming.
post Nov 5, 2003 - 10:43 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
First off, a sway bar is is a link between the struts for less movement between them for a better tighter handling......the link is just the link between the sway bar and the strut assembly....
Ok my real question... where is this shop? whats the name?
post Nov 5, 2003 - 10:49 PM
Cormudgen
Joined Jul 31, '03
From GA
i think he did a pretty good explanation of what it is and what it does so i won't touch upon that farther. i will tell you though that the linkages are NOTORIOUS for stripping and many people on here have had a problem. you almost have to take them off to adjust anything on your rear suspension so many people have run into the problem of stripping them and then having to put up with them rattling.
as for where this store is, it is a chain. very similiar to autozone or napa. i assumed it was nation but def all over the southeast. you can order online as well at
www.partsamerica.com
*edit*it appears the old Discount Auto parts is now called Advanced Auto Parts*edit*
post Nov 5, 2003 - 11:26 PM
macavely
Joined Nov 4, '02
are you talking about those that come in the yellow packaging with the red bushings? if please let us know how they feel cause i was thinking about getting them..
post Nov 5, 2003 - 11:36 PM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
I've already bought two sets of those at autozone for 12.99 a pair. Every car I've owned i've had to replace them. They're easy to put on but I hate taking them off,especially when they snap in half.
post Nov 5, 2003 - 11:45 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Wait what you mean 13 bucks a pair?? are you talking about the sway bar links? and how do they break or snap as you said? are they that cheap.....
post Nov 5, 2003 - 11:47 PM
Cormudgen
Joined Jul 31, '03
From GA
QUOTE (macavely @ Nov 5, 2003 - 9:26 PM)
this is definetly not what i'm talking about.....its the whloe linkage bar, not bushings and the packaing is brown with blue leterring. i think "trw" may be the brand.
post Nov 5, 2003 - 11:49 PM
Cormudgen
Joined Jul 31, '03
From GA
QUOTE (95STHATCH @ Nov 5, 2003 - 9:36 PM)
i'm assumin we are talking about differint things. autozone told me they don't sell end linkages for our car. that would be wonderful if my store was wrong though and we can get them for $13. even if thats not for the pair
cormudgen
post Nov 6, 2003 - 12:02 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Ok, I checked that site, and i found some that i think are it.... they dont discribe anything and the only one with a pic, it looks right, but are 50 bucks.....
Do you by chance know the modle number?
This post has been edited by Digndoug: Nov 6, 2003 - 12:03 AM
post Nov 6, 2003 - 12:10 AM
95STHATCH
Joined Jun 21, '03
I think i'm talking about something different, i was talking about the sway bar linkage bolts and bushings set,not the sway bar itself. Sorry bout that. I will shut up now biggrin.gif
This post has been edited by 95STHATCH: Nov 6, 2003 - 12:12 AM
post Nov 6, 2003 - 2:19 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
hey guys... after stripping mine i asked my friends at my dealership... just use a vise grip (from behind where the rubber boot is) and an impact gun to get them right off/ tighten them up..
post Nov 6, 2003 - 2:26 PM
Rivo
Joined Apr 28, '03
lol zips, not all of us have access to an impact gun at our home.
post Nov 6, 2003 - 3:39 PM
macavely
Joined Nov 4, '02
well you can go to sears and use that striped bolt remover it works great.. thats what i use on my brake caliper .
post Nov 10, 2003 - 4:09 PM
FallenHero
Joined Dec 26, '02
From Alabama
Get the new super street (with the AE-86 on the front) and look at page six. It says Rear camber and toe adjustment. Are those the pieces you guys need?
post Nov 11, 2003 - 7:32 AM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
anyone have a picture of a stripped sway bar link ( or even a sway bar link for that matter) for the people that got no idea what the hell your talking about?
post Nov 12, 2003 - 2:28 PM
97GTinKC
From KC
Pic in this thread of my replacement ones I made, kind of shows you where they go, this pic is of the rt. front taken from low on the right front side, lower end is bolted to the control arm tab, upper end is bolted to the sway bar, the OEM Toyota ones have a ball and socket with a rubber boot instead of these rod ends, the stud on the OEM ones has a hex in the end so you can hold it with an Allen wrench while loosening the nut, If the allen part strips out, then you usually have to cut them off or use the visegrips to clamp it in the rubber boot area to keep the threaded part from turning.
http://www.6gc.net/forums/index.php?showtopic=6221
The rear are the same setup, only longer
post Nov 17, 2003 - 11:17 AM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE (Rivo @ Nov 6, 2003 - 12:26 PM)
i dont have one either frown.gif i borrowed toyota's
post Jan 6, 2004 - 9:17 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE (Cormudgen @ Nov 6, 2003 - 1:45 AM)
cormudgen
ok, I know im bringing back up the dead or what not, but i wanted to know how the links worked, you responded to one of my previous questions saying you still need to get some....wasnt sure what ahppened and where i might be able to get those for 25 bucks each or so
post Jan 6, 2004 - 9:20 PM
Cormudgen
Joined Jul 31, '03
From GA
i thought i had replied. but anywyas it turns out that the cheap ones are for the front. they are like 2 mm to short. dealer is still only like $3 more than the ones discount auto parts sells. supposedly though, they are the same brand and toyotas has a shorter warranty.
cormudgen
Lo-Fi Version Time is now: February 18th, 2025 - 5:11 AM
