> What does your car idle at?
post Nov 5, 2003 - 10:54 PM
Stealths95GT
Joined Apr 19, '03
From Washington
i think there is something wrong...but i don't know...my exhaust is acting funny and i didn't pay attention to what i was idleing at...im at 800 and i thought it was around 1200 idle..but like i said...didn't really pay attention...
post Nov 6, 2003 - 1:03 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
cold start 1400
AC on, warmed up 950
sitting at idle in park 650
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Nov 6, 2003 - 1:19 PM
Why does ur car idle higher when ur AC is on?
post Nov 6, 2003 - 2:08 PM
Pandeo
Joined Mar 18, '03
From Quebec
It's because the motor have more pulley to turn, so It need more revolution to support the extra job. Test this; run normaly with your car for 1 week without AC, and 1 week with AC; you should see a difference in fuel consommation.
I think that your car is supposed to idle to 8000 rpm. But i'm not sure
post Nov 6, 2003 - 5:05 PM
1bwilson
Joined Aug 30, '02
From Maryland
-Bryan-
Member of Team 5sfTe
post Nov 6, 2003 - 7:24 PM
Stealths95GT
Joined Apr 19, '03
From Washington
i don't know...must have been the weather...cause it's running just fine...thanx anyway
post Nov 6, 2003 - 7:56 PM
Generally your car runs lower with the A/C on... your car doesnt increase revs to compensate on its own.
post Nov 6, 2003 - 8:02 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Supersprynt @ Nov 6, 2003 - 4:56 PM)
mine does, as with my 93 protege and my mom's 525i
vacuum also drops on my car a bit if the AC is on.
post Nov 8, 2003 - 6:42 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
QUOTE (97sccelica @ Nov 6, 2003 - 6:02 PM)
Mine is automatic so it idles at less than 600 because of the S-AFC...it hurts me seeing her do that, though... frown.gif
post Nov 8, 2003 - 8:10 PM
Good indication that you have a vacuum leak if ur cars idling that high. Turning more belts and having more electronics causes the car to use more power.
post Nov 9, 2003 - 4:38 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Supersprynt @ Nov 8, 2003 - 5:10 PM)
my vacuum holds at 20mm hg(i think those are the units on my gauge) when at idle(in or out of gear) and runs at 650-660rpm
im very certain that i dont have a vacuum/boost leak anywhere in the sytem
oobe,
what settings do you have to make ur idle rpm so low? i have an auto as well and my low throttle curve is -10% all through the rpm range
post Nov 17, 2003 - 1:45 PM
VlaCelica
Joined Nov 10, '03
From Netherlands
mine is around 900 when the engine is warmed up. When its cold its around 2000.
This post has been edited by VlaCelica: Nov 17, 2003 - 1:46 PM
post Nov 17, 2003 - 1:57 PM
LatinKraze
Joined Oct 22, '03
QUOTE (VlaCelica @ Nov 17, 2003 - 10:45 AM)
Diddo, same here.
Edit: not 2000 when cold, more like 500-600rpm
This post has been edited by LatinKraze: Nov 17, 2003 - 1:58 PM
post Nov 19, 2003 - 3:07 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
QUOTE (97sccelica @ Nov 9, 2003 - 2:38 AM)
oobe,
I don't know, man, I can't remember, all I know is that the engine was idling so low I couldn't hear it and it was a cunt hair away from dying....plus I think I installed the S-AFC incorrectly. It works fine and changing the graphs had an effect on the engine, but I think I missed something. I had a hard time translating the pinouts and the diagrams from the manual because there was no 7A-FE, only 4A-FE but it looked exactly like the 7A-FE. I used the t-5b diagram. Which one did you use? I checked Speedtoe's instructions and I don't recall installing it like he's saying, But his instructions are for manual trany...but it shouldn't be any different, right? Anyway, let me know which diagram you used, because you guys have ran better than me...I didn't even enjoy boosting because in less than 4 seconds, the EGT skyrocketed to 1,300-1,400 degrees. frown.gif
post Nov 19, 2003 - 11:16 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
auto and manual ecu's are the same, the wiring in the connectors that is.
my celica is a 97 so the ecu wiring is different but i decifered it from my chiltons manual(what a crappy book)
there was no diagram for my year, there is one that is close, but i think one of the wires was wrong.
Lo-Fi Version Time is now: January 7th, 2025 - 12:01 PM
