delete post!, DELETE |
Feb 1, 2010 - 1:21 PM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
So i bought a "new" 7A-FE and it has 60k on it (obviously was drained and cleaned before i put it in) and I put in I think Castrol 10W-30
And I just wanted to know If i can still switch to synthetic? Or will it mess with my internals? And what exactly is the advantage of using synthetic? cleaner? last longer? tell me what I should do! thanks- This post has been edited by mgnt232: Feb 3, 2010 - 8:08 PM -------------------- |
Feb 1, 2010 - 11:22 PM |
synthetic you can use. It lasts longer, cleans your walls better, and better for abuse, i mean performance
Feb 1, 2010 - 11:36 PM |
Enthusiast Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
It may mess with seals, the problem with it is it cleans the engine too thoroughly and sometimes can clean it too much that the old oil around the seal is cleaned too much and creates oil leaks.
although 60k isn't too much so it should be alright, I changed mine at 200k and only got one seal that started leaking. |
Feb 2, 2010 - 1:48 AM |
Ha! that was pretty funny... what kind do you recommend?
synthetic you can use. It lasts longer, cleans your walls better, and better for abuse, i mean performance -------------------- |
Feb 2, 2010 - 6:58 PM |
Enthusiast Joined Nov 27, '09 From New York USA Currently Offline Reputation: 5 (100%) |
You should Try 5w30 I personally use Mobil 1. But am pretty sure there are other options too....
Feb 2, 2010 - 10:21 PM |
Ha! that was pretty funny... what kind do you recommend? synthetic you can use. It lasts longer, cleans your walls better, and better for abuse, i mean performance That may or may not be a myth that it cleans it too well to affect it that bad. But if it does create leaks, seals should've been replaced anyways or your car hasn't been maintained very well. Synthetic is proven to be a better oil. Mobil 1 is commonly used but I use Royal Purple. -------------------- 94 Celica GT
Feb 2, 2010 - 10:34 PM |
Enthusiast Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
5w-30 synthetic mobil1 oem toyota filter
Feb 3, 2010 - 10:37 AM |
Enthusiast Joined Jan 25, '10 From Manila, Philippines Currently Offline Reputation: 0 (0%) |
hey where can i locate that oil filter?
Feb 3, 2010 - 11:00 AM |
hey where can i locate that oil filter? dealership... online. sorry i don't have a part#. the oem filters are the best because of the pressure relief valve... fram and that other aftermarket stuff is garbage! -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 7:37 PM |
