![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) ![]() |
So my heat like barely works... not sure why last winter it worked great? its blows out..just not heat lol... so I have an idea with a 2000C-4000M watt inverter I have laying around.. hear me out
The heater is a 1500Watt, and the inverter is 2000 Continuous and 4000 Max, So im pretty sure it will work in that aspect. But I am wondering if I can run it off my "stock" electrical system? I have 2 batteries (rear Kinetik) but running on the stock alt because my 220Amp alt over heated. Can I run the heater? or should i wait to get my high output alt fixed and back (in a few days) Or does anyone know why my heat just doesnt work anymore? thanks! This post has been edited by mgnt232: Feb 3, 2010 - 8:08 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) ![]() |
pop your hood
You will see a cable that comes out of the top driver side firewall, with a round hook on it that connects to a small black box...take your hand and move that little hook all the way over...either to the right or the left. Get in a start your car and let it warm up...then go back out under your hood and move it all the way to either the right or the left, doesnt matter....get in your car and see if it's blowing hot/cold...if its blowing cold, get out and shift it to the other side, if its blowing nice and hot, problem fixed...just take your knob on the climate control and re adjust it. I hope you understand what i am talking about...its not that hard Its either that or you blew your heater core A heater core is cheap...but its the labor thats going to kill you. -------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Enthusiast ![]() Joined Jun 9, '09 From Saint Louis Currently Offline Reputation: 0 (0%) ![]() |
Just wondering, is your water temp gauge coming up to normal operating temp? Somewhere in the middle. If your termostat is stuck open your coolant in NY will barely get hot enough to heat your car.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
i personally would not run a heater inside a car simply because our toyota charging systems are very weak. Even if your inverter can power the heater, doesn't mean your alternator can make that much power.
If your not getting heat through your radiator, its most likely your heater core is clogged or broken. |
Enthusiast ![]() ![]() Joined Mar 19, '09 From Malden, MA Currently Offline Reputation: 2 (100%) ![]() |
This will not work. Plain and simple. Just try and fix your heat.
The electrical system will overheat / malfunction / blow up / and destroy everything. 1500Watts is A LOT of power. If you think about it this way... Watt's law says -- 1Watt = 1 Volt X 1 Amp We know watts = 1500 We know volts (car on) = ~13 volts Therefore Amps = 1500/13 = 115 Amps A stock alternator puts out like between 60-80 Amps (At full capacity). Therefore, you will not only destroy your alternator, but you run the risk of blowing fuses and melting the wires that carry that kind of current. |
thread jacking,
where can i get a cheap heater core... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
i'm willing to bet that all you need is replace your thermostat and you'll get your heat back.
thread jacking, where can i get a cheap heater core... from here.. just make a wtb thread. ![]() -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
It heats up normal, goes just about the middle. The heat worked fine just last year... for whatever reason now it doesnt work too great.
Just wondering, is your water temp gauge coming up to normal operating temp? Somewhere in the middle. If your termostat is stuck open your coolant in NY will barely get hot enough to heat your car. -------------------- |
Well what about when I get back my mechman alt (a few days) I have all 1/0 gauges wiring, and my other alt is 150 idle and 220 amps at 3k
This will not work. Plain and simple. Just try and fix your heat. The electrical system will overheat / malfunction / blow up / and destroy everything. 1500Watts is A LOT of power. If you think about it this way... Watt's law says -- 1Watt = 1 Volt X 1 Amp We know watts = 1500 We know volts (car on) = ~13 volts Therefore Amps = 1500/13 = 115 Amps A stock alternator puts out like between 60-80 Amps (At full capacity). Therefore, you will not only destroy your alternator, but you run the risk of blowing fuses and melting the wires that carry that kind of current. -------------------- |
Brand new thermostat
![]() i'm willing to bet that all you need is replace your thermostat and you'll get your heat back. thread jacking, where can i get a cheap heater core... from here.. just make a wtb thread. ![]() That makes sense, I will be looking tomorrow ![]() pop your hood You will see a cable that comes out of the top driver side firewall, with a round hook on it that connects to a small black box...take your hand and move that little hook all the way over...either to the right or the left. Get in a start your car and let it warm up...then go back out under your hood and move it all the way to either the right or the left, doesnt matter....get in your car and see if it's blowing hot/cold...if its blowing cold, get out and shift it to the other side, if its blowing nice and hot, problem fixed...just take your knob on the climate control and re adjust it. I hope you understand what i am talking about...its not that hard Its either that or you blew your heater core A heater core is cheap...but its the labor thats going to kill you. -------------------- |
Lo-Fi Version | Time is now: February 22nd, 2025 - 11:41 PM |
