5 Pages V  « < 2 3 4 5 >
> Installed RacingBeat Rear Links, ..goodbye TwosRUs
post Aug 2, 2010 - 10:51 AM
azian_advanced
Joined Apr 18, '05
From Calgary
nvm
This post has been edited by azian_advanced: Aug 2, 2010 - 10:53 AM
post Feb 10, 2011 - 10:45 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
how about these for the front sway bar links??? they should be better than the two's r us????
http://cgi.ebay.com/FRONT-SWAY-BAR-END-LIN...=item45f832621b
post Feb 10, 2011 - 11:33 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
QUOTE (BonzaiCelica @ Feb 10, 2011 - 10:45 PM) *
I dunno, but they sure don't LOOK better than the Twos R Us ones. Lol. Plus they aren't adjustable.
June '12 COTM
'95 AT200
post Feb 11, 2011 - 2:39 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (HectortheRican @ Feb 10, 2011 - 11:33 PM) *
hmm ya they look like the thickness of stock ones. I'll just go with two's r us up front just to be safe as other members have used them with good results.
post Feb 11, 2011 - 1:17 PM
HectortheRican
Joined Dec 26, '09
QUOTE (BonzaiCelica @ Feb 11, 2011 - 1:39 AM) *
I already have the Racing Beats in the rear and I'll be getting the ST185 Twos R Us fronts when I buy the F/R ST sways.
June '12 COTM
'95 AT200
post Apr 22, 2012 - 6:44 PM
trdproven
Joined Aug 2, '05
From Guam
Heres other cars that show they have the same front suspension end links. maybe someone would want to research if these other cars have good aftermarket ones. i kinda doubt cus the rest are grocery getters but something to take a look at. you just have to figure out between the cars if the fronts or rears is the same because you could use a front link for a rear link in another car, depends.
Anyway whats a good endlink vs cost of regular ones. I found these for a 5th gen, http://www.ebay.com/itm/CELICA-ST182-ST184...=item20c4e54dff. It looks like its mixing the bushing arm type end link to make it fit our right angle end links. Less of a spherical movement now and just more of a damn bushing to be honest from the picture - similar to racingbeat. What are you guys thoughts on the design? OR get the Mevotechs that are basically OEM replacements that are Beefier. http://www.6gc.net/forums/lofiversion/inde...73360-2650.html
Toyota
Celica (94-99) AT200 ST204
Camry (92-96) SXV10 MCV10 VCV10
Avalon (95-96) MCX10
Corolla (93-02) AE101 AE102 ZZE110
Rav4 (96-00) (2DR) SXA15 SXA10
Lexus
ES300 (92-96) VCV10 MCV10
This post has been edited by trdproven: Apr 22, 2012 - 7:20 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 22, 2012 - 7:00 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
http://www.gt4-racing.eu/index.php/toyota-...-sway-bar-links
Here's some for the front and rear.
My Celica!
post Apr 22, 2012 - 8:03 PM
trdproven
Joined Aug 2, '05
From Guam
the design concept sounds good because you dont have to worry about adjusting it correctly and it comes with upgraded bushings. OEM are just OEMs and Racing beat/twosrus are adjustable, stronger links but i guess I don't really need the adjustability part, unless that affects how much lower you can go.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 22, 2012 - 9:45 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I don't think so.
I but the adjustable oens from twos r us, and they are adjustable.
I'm not even sure why or how you would need to adjust them, or what benefit it would have.
I simply installed them right out of the box, as is and haven't touched them since.
How would adjusting them benefit you?
My Celica!
post Apr 22, 2012 - 9:48 PM
Doesn't the relation between the two end link mounts change in coordination with the "height" of the suspension setup? Roughly speaking, OEM suspension setup will take a longer end link, whereas using coilovers to lower will require a shorter endlink?
This post has been edited by SwissFerdi: Apr 22, 2012 - 9:49 PM
post Apr 22, 2012 - 10:25 PM
trdproven
Joined Aug 2, '05
From Guam
^ thats the general concept, the other thing is how much do you adjust besides shortening them because of the lowered ride height, im guessing when studs become horizontal while the car is on the ground or on flat.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 22, 2012 - 10:28 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (SwissFerdi @ Apr 22, 2012 - 10:48 PM) *
No.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Apr 23, 2012 - 9:06 AM
trdproven
Joined Aug 2, '05
From Guam
^ actually, it is common to use shorter endlinks especially when your car is lowered. if not, you have both studs stressing pointing down or up. you can feel the stress they take in order to put them on. I only noticed this on my 7th gen, and it is common talk on forums.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 23, 2012 - 9:56 AM
azian_advanced
Joined Apr 18, '05
From Calgary
the links need to be of equal length so that the sway bar isn't pre-stressed.
while pre-stressing is not necessarily a bad thing, it just means that you won't get the same roll stiffness doing LH turns as you would doing RH turns (and vice versa).
they're also adjustable so that you can change the direction of force the end link is putting on the sway bar the moment you start getting body roll.
ideally, you want the link to be 90 degrees with the sway bar where it meets the sway bar bushings. it'll allow more torque to transfer from one end of the sway bar bushing to the next during cornering.
basically, it'll maximize the performance of the sway bar.
i made a diagram to show the angle i'm referring to.
during auto-cross events where you're always cornering left and right & putting more cornering loads on the suspension, it'll be better to have it at a slightly higher angle.
for example, if at maximum cornering load the angle (in the picture) reaches a minimum of 86 degrees which is when the suspension achieves its highest length of travel giving you a maximum deflection angle of 4 degrees (90-86=4), then it would be better to have it set to around 92 degrees when static (90+4/2=92) so that deflection angles range between 88-92 degrees and always maximizing the anti-roll performance of your set-up.
This post has been edited by azian_advanced: Apr 23, 2012 - 10:11 AM
post Apr 23, 2012 - 11:46 AM
Culpable04
Joined Apr 17, '06
From New Jersey
^ because of that reason, if you ever take your car to be corner balanced for a racing setup ( or DD pleasure lol ) you'll be require to have adjustable end links along with coilovers. the end links are used to transfer small weight loads from side to side to " balanced " the weight distribution of the car.
post Apr 23, 2012 - 5:09 PM
trdproven
Joined Aug 2, '05
From Guam
but what are the advantages between spherical and this bushing bolt type? would it be alright to get the GT4 Racing endlinks that have poly bushings but no adjustability?
This post has been edited by trdproven: Apr 23, 2012 - 5:10 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 23, 2012 - 8:56 PM
azian_advanced
Joined Apr 18, '05
From Calgary
the ball-joint type endlinks allow some independent suspension travel before any torque is transmitted through the sway bar. they're ideal for a more comfortable ride especially if you hit bumpy roads often.
the good thing about TwosRUs links are that they have adjustable lengths so that you can adjust the amount of suspension travel but the ball joint's degree of rotation is a little high if you're already on lowering springs and especially if you're on coilovers since suspension travel is already shortened.
those gt4 racing endlinks are not only non-adjustable but they're also overpriced. the racingbeat links are half the price, adjustable, and have better quality judging from the pics.
This post has been edited by azian_advanced: Apr 23, 2012 - 8:57 PM
post Apr 24, 2012 - 6:51 PM
trdproven
Joined Aug 2, '05
From Guam
i looked at the racingbeat ones and they seem to be more expensive 65, vs gt4 ones at 50some. which ones are they and arent they only for the rears?
i might end up getting the beefier Mevotechs, idk yet.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 27, 2012 - 5:36 PM
TerBeau
Joined Nov 25, '08
From dillsburg pennsylvania united states
Didn't read farther but will the sway bars fit too? Just curious
those with golf balls golf
those with real balls race
post Apr 27, 2012 - 6:24 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (trdproven @ Apr 23, 2012 - 10:06 AM) *
They are not necessary. They would not be stressed unless presented with excessive lowering, which in turn would mean a decrease in performance. Lowering the car too much doesn't necessarily make it handle better, also "common talk on forums". Aftermarket endlinks are only needed for a road car once it has been lowered beyond what is good for performance, or when aftermarket swaybars are used, or both.
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 26th, 2024 - 6:48 AM
