> GT4 st205, Fuel Problems
post Feb 6, 2010 - 2:13 PM
longgone
Joined Feb 5, '10
From ireland
Hi
Can anyone tell me if they have a solution to this problem
the car cut out the other day and now wont start
It turns over but wont fire
I checked it with easy start and it fired straight away
So then I checked the fuel pump and it works then I tested the fuel relay and it seams ok
I checked the fuel pump resistor with a multimeter and it looks good
I went back to the fuel pump but don't have power to the pump even though the pump works fine when on a battery
anyone any ideas
post Feb 6, 2010 - 5:01 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
clean the injectors?
Check the fuel pressure regulator?
replace the fuel filter?
See if the pickup in the tank is dirty?
post Feb 7, 2010 - 11:08 PM
Rusty
Joined Nov 5, '07
From New Zealand
3rd gen 3S-GTE engine repair manual
^ this is the should help you (its quite big 32.5MB) look for the trouble shoot section
This post has been edited by Rusty: Feb 7, 2010 - 11:08 PM
post Feb 8, 2010 - 6:02 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
QUOTE (longgone @ Feb 6, 2010 - 3:13 PM) *
Hi
anyone any ideas
If i were u...i would check the following...
-battery
-spark plugs
-spark wires
-ignition module
-fuel filter
-fuel pump
-fuel regulator
-check for fuel leaks aswell
-and at last make sure you r getting enough cold air...
if it still dont work, then it might be your ecu...
post Feb 9, 2010 - 4:49 PM
longgone
Joined Feb 5, '10
From ireland
QUOTE (Rav4Race @ Feb 8, 2010 - 6:02 AM) *
Hi
anyone any ideas
-battery
-spark plugs
-spark wires
-ignition module
-fuel filter
-fuel pump
-fuel regulator
Hi dudes thanks for your comments
I checked the battery it's good
spark plugs are new and they spark
fuel filter is new
I took off the fuel pump and it works ok then when i was using it to empty the tank as I took the tank out without doing it
I noticed that there was a pin hole in the pipe from rust
so I got it repaired put it back in but still not pumping to front
so I checked for power at the fuel pump relay no power there
so I put a wire from the + on battery to the no 3 pin on the relay now car will start
so there is no broken wire from the relay to the pump
now I think it might be the ecu so tomorrow I'll have to check the fpr wire out of the ecu
anyone have anymore ideas need to get this goin soon
post Feb 14, 2010 - 4:15 PM
longgone
Joined Feb 5, '10
From ireland
Hi folks problem is now solved
I took out the 3 fuses that resets the ecu
1 hazzard fuse 2 ecu fuse and 3 efi fuse
then i took out the battery and fully charged it
tightened up the fuel pipe out of the tank
and now it's going good
thanks to all that sent me info
post Feb 14, 2010 - 4:18 PM
longgone
Joined Feb 5, '10
From ireland
Lo-Fi Version Time is now: January 10th, 2025 - 1:14 AM
