> wiring amp, to stock unit
post Nov 6, 2003 - 6:29 PM
Cormudgen
Joined Jul 31, '03
From GA
ok, i have a stock head unit. the only thing i am not sure of the best place for is the REM wire. i've had it goin to the ignition fuse int the driverside fuse panel for the past 2 months but recently my battery died and i'm unsure if it was related. someone said that having it wired that way was putting a constant draw on the battery. what is your recomendation for wiring the the Rem wire?
thanks
cormudgen
post Nov 6, 2003 - 7:47 PM
The deck power wire.
usually red.
This post has been edited by Supersprynt: Nov 6, 2003 - 7:48 PM
post Nov 6, 2003 - 9:00 PM
Cormudgen
Joined Jul 31, '03
From GA
sounds like a good idea, don't know why i didnt think of that originaly.....not sure why nonoe has suggest it previous to you either. will do that this weekend.
cormudgen
post May 12, 2008 - 4:13 PM
wannabealilfaste...
Joined Oct 17, '07
From San Diego
sorry to bring up a dead topic but... I'm also trying to do the same thing but i have two red wires which one is it?
post May 12, 2008 - 4:49 PM
D-Man
Joined Jan 18, '08
From Houston
personally i believe in toggle switches as well...
Damn D-Man - most impressive.
post May 12, 2008 - 5:03 PM
QUOTE (D-Man @ May 12, 2008 - 5:49 PM) *
for the amP?
then yes..... I have found a oem switch that i will try to modify for this...
Lo-Fi Version Time is now: November 23rd, 2024 - 1:19 PM
