> amp keeps blowing fuses, help
post Feb 9, 2010 - 8:18 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
ok so i have a 500 watt amp which has worked fine for me the past few months, now i should say that when i first installed the amp it was all run down the drivers side of the car, i had the alternator hum so i bought a ground loop isolator to fix this, it worked and i left it at that. now today i got my new rear speakers, so i had to pull all of the back of the car out to install them, and i figured while i was at it i should pull the rca cables back to the head unit and run them down the passanger side. so i get all this run and i hooked the rca cables into the back of the stereo, i left the ground loop isolator still hooked up to the grounds but didnt use it, so the amp keeps blowing fuses as soon as it is turned on, can anyone help me out with this
2001 Solar yellow Lexus IS300
post Feb 9, 2010 - 9:28 PM
Sounds like a short. You should check all your wiring.
This post has been edited by Supersprynt: Feb 9, 2010 - 9:28 PM
post Feb 9, 2010 - 10:51 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
a short is a good diagnosis!
post Feb 9, 2010 - 11:58 PM
96stgreendemon
Joined Oct 7, '09
checked for shorts but none to be found
post Feb 11, 2010 - 8:53 PM
trdproven
Joined Aug 2, '05
From Guam
there is a short in your wiring or a short on your amp.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 12, 2010 - 12:13 AM
96stgreendemon
Joined Oct 7, '09
ok so i was using the wrong fuses im a tard, now it crackles and goes back and fourth from on and protect mode
post Feb 25, 2010 - 8:02 PM
mgnt232
Joined Mar 16, '09
I had a little amp like that when I was like 15 and I blew the fuse, put the wrong one back in and it did the same thing urs is doing. I am not amp repair man but I could get it to work ever again (just back and forth as you described) I would suggest just getting a new amp... a BIGGER one smile.gif
And I would double check ur wiring too.
QUOTE (96stgreendemon @ Feb 12, 2010 - 12:13 AM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
Lo-Fi Version Time is now: November 28th, 2024 - 6:30 AM
