Vaccum line, NEED ANSWER ASAP |
Feb 10, 2010 - 7:48 PM |
Enthusiast Joined Jan 11, '10 From Chicago Illinois Currently Offline Reputation: 0 (0%) |
was about to run my boost gauge then foundout sum info. i heard there is more than 1 vacuum line and need to know which one to connect my boost gauge too!! THANKS
Feb 10, 2010 - 11:05 PM |
anyone???
Feb 11, 2010 - 1:05 AM |
Enthusiast Joined Aug 5, '09 From Oakley, CA Currently Offline Reputation: 15 (100%) |
Eh, since no one else is responding I'll go take a pic where I cut my vacuum line... Back in a few.
I want a raise. -------------------- 1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver |
Feb 11, 2010 - 1:19 AM |
"There I fixed my vacuum leak." Lmfao. EDIT: And yes, I'm super ghetto. Hahahaha. A screw actually does a pretty good job to keep the air in there! I'll fix it this weekend, promise This post has been edited by johnnehh: Feb 11, 2010 - 1:20 AM -------------------- 1996 Toyota Celica GT (GT4 conversion) - SOLD :(
Feb 11, 2010 - 7:56 AM |
Enthusiast Joined Feb 6, '08 From Latvia Currently Offline Reputation: 0 (0%) |
you can connect to any vacuum line as long as it comes out of the intake manifold.. check where you have boost sensor for Fuel Cut feature, its somewhere near the firewall. cut that hose, as fuel cut is a such rare feature that you dont care if it lags a millisecond or not..
-------------------- 1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ |
Feb 11, 2010 - 9:44 AM |
Enthusiast Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) |
^^^ Agreed. You should tap it here Mike.
This is the same spot that I tapped into on my alltrac. -------------------- ~bloodMoney
Feb 11, 2010 - 12:43 PM |
Iiggt for sure. Thanks alot, and for the wideband which spot do I put the o2 sensor into
Feb 11, 2010 - 1:51 PM |
You are going to need to wait on the wideband b/c you don't have a properly threaded port in the exhaust flow to screw the sensor into. Once you put the new stuff on the car, you are going to have an exhaust shop weld in a bung for the sensor. But right now you can't run the wideband just yet. Sorry bud
Feb 11, 2010 - 6:18 PM |
Ok and as foe the line from the boost gauge to the vacuum line, where is the easiest spot to run it through
Feb 11, 2010 - 7:00 PM |
Since you're on that side of the bay anyway, why not just run it through the same spot as the ECU harness?
Feb 11, 2010 - 7:41 PM |
that vacume line is the boost refrence for the fuel pressure regulator. personally i dont mess with that line. i got my boost gauge refrence from the other side of the intake manifold. there was a nipple with a factory plug on it. remove plug, viola!
Feb 12, 2010 - 12:04 AM |
smaay i did exactly wat u said, found 2 nipples!!! ha anyways, goood idea and thanks, saved me time and patience!
Lo-Fi Version | Time is now: January 10th, 2025 - 3:12 PM |
