> OEM FOGLIGHT INSTALL! NEED HELP!!!
post Feb 12, 2010 - 5:15 PM
JDUB
Joined Jun 5, '08
From Portland, Oregon
i just bought some oem preface foglights
i need to know, what size bolts i need to mount them up,
the wires were cut, about a inch of wire there still
and also what else do i need for the install and HOW to, thanks
(links would help, for where to buy this stuff)
post Feb 12, 2010 - 5:19 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (JDUB @ Feb 12, 2010 - 6:15 PM) *
1sttoyotaparts.com
http://www.6gc.net/forums/index.php?showtopic=38656
but that link is for 96+ it might be of some help tho
This post has been edited by benzo: Feb 12, 2010 - 5:20 PM
post Feb 12, 2010 - 6:14 PM
Remy
Joined Jan 25, '06
From MN
When I installed mines their were bolts on the crash bar already check ur crash bar you might have bolts where it lines up already.
"To Protect And To Serve The Wealthy" -POLICE
post Feb 12, 2010 - 6:45 PM
GriffGirl
Joined Feb 7, '07
IIRC it's either 12mm or 14 mm bolts in there; pretty sure it's 12. Home Depot is your friend.
post Feb 12, 2010 - 8:28 PM
GrimReaper
Joined Jul 27, '07
From Québec, Canada
It's 5 or 6mm 1.25 or 1.5 threads, with 10mm heads for the bolts. It's the exact same bolts as for the horns, so you can use one of these to get the same bolts.
You'll need to remove the lower mud shield to access the very outside bolts (plz forgive my english here!!), it's pretty tricky and you might have to pry the bumper cover to reach them from under the car.
Hope this will help.
This post has been edited by GrimReaper: Feb 12, 2010 - 8:38 PM
post Feb 12, 2010 - 8:56 PM
JDUB
Joined Jun 5, '08
which boltttt? lol there was like 3 differnt answers, wat else do i need other than the bolts
post Feb 13, 2010 - 12:40 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Go to autozone and buy the big ass import bolt kit, that's what I used in mine
2001 Solar yellow Lexus IS300
Lo-Fi Version Time is now: January 16th, 2025 - 8:52 AM
