I need some answers PLEASE... |
Feb 13, 2010 - 4:26 PM |
Enthusiast Joined Jan 14, '08 From UAE Currently Offline Reputation: 0 (0%) |
Hi,
I got st202 with a st205 3sgte, and I got some questions... I want to change my clutch and I was wondering, is there a difference in the clutch between the 2nd and 3rd Gen 3sgte ??? and what clutch you guys recomend for 400-450WHP, Im thinking of Competition Clutch stage 5??? I run the 3sge (red top beams) transmission... Is there any aftermarket motor mount for the st202, the stock mount dont seem to hold too much abuse??? Help will be apreciated Thanks. This post has been edited by CeLiCa_ST: Feb 13, 2010 - 4:28 PM -------------------- |
Feb 13, 2010 - 5:08 PM |
Enthusiast Joined Sep 11, '08 From Surrey Unitedkingdom Currently Offline Reputation: 1 (100%) |
It all depends on what type of transmision you have. Check the VIN plate and see the type of transmision - it will eighter be a S54 or the LSD equiped E56 which uses the same clutch as the ST205/ST185.
For engine mounts you can use these from ebay - http://cgi.ebay.co.uk/POLYURETHANE-ENGINE-...=item45f09e6a34 |
Feb 13, 2010 - 9:37 PM |
thanks for the help,
Im thinking of Competition clutch is it any good ??? as I remember I used the GT4 clutch, and the gear was LSD.. about the mounts, I have to press them in right ??? This post has been edited by CeLiCa_ST: Feb 14, 2010 - 12:53 PM -------------------- |
Feb 25, 2010 - 6:35 AM |
Enthusiast Joined Sep 28, '09 From Washington, MO Currently Offline Reputation: 0 (0%) |
look into the Exedy multi-plate clutch for the st205 for a good twin plate clutch, or there's a good one by ACT released in.... i think it was 2005....
TM1-HDG6 - http://www2.advancedclutch.com/products/cl...od_id=6206#6206 TM012SR - http://www.exedyusa.com/race/Clutch_Specifications look through both sites, and pick something that works with your goals... i'm needing something that can run up to 500whp on FF with a highly modified '94GT running the WRC st205 3S-GTE... those are the two clutches i'm looking at right now, as i should have the engine and tranny sitting at home awaiting my return this december... |
Mar 2, 2010 - 4:43 PM |
Enthusiast Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
It all depends on what type of transmision you have. Check the VIN plate and see the type of transmision - it will eighter be a S54 or the LSD equiped E56 which uses the same clutch as the ST205/ST185. For engine mounts you can use these from ebay - http://cgi.ebay.co.uk/POLYURETHANE-ENGINE-...=item45f09e6a34 The S54 clutch will not fit the ST205 transmission buddy I tryed i wish it did -------------------- |
Mar 2, 2010 - 6:34 PM |
yeah it all depends on what flywheel you have, if you ahve a 3S-GTE flywheel then you need a 3S-GTE pressure plate, but the disk has to match up to the splines on the shaft of the tranny, so you might need a hybrid clutch.
Lo-Fi Version | Time is now: November 24th, 2024 - 1:55 AM |
