does anyone have 5th gen mirrors, if so i have a question... |
Feb 15, 2010 - 2:45 PM |
Enthusiast Joined Jul 13, '09 Currently Offline Reputation: 9 (91%) |
i have just fitted some 5th gen Celica mirrors onto my 6th gen vert and all seemed to go well except, the power adjustment goes in the wrong direction, up is left, down is right, right is up and left is down. it all works but its quite annoying. so my question is two fold, 1st is this common? 2nd is it worth the hassle to fix or do i just adjust them and call it a day? i hate messin with the wireing especially since they do work but don't want the problem to get worse for me ignoring it. please give me some advice!
-------------------- You're here for a good time, not a long time. - Colin McRae When in doubt... Flat out! - Colin McRae Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you.... |
Feb 15, 2010 - 5:28 PM |
Enthusiast Joined Aug 11, '09 From Buffalo, NY Currently Offline Reputation: 15 (100%) |
Sounds to me like you just need to rotate the wires in the harness. Unpin them and move them all one spot clockwise. Before you seal everything up, test and repeat. If you notice in your post, whatever button you press does what the button one spot counter clockwise of it does. That should fix it.
Feb 16, 2010 - 3:42 AM |
Enthusiast Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
White mirror wire goes to black wire from your harness
Red mirror wire goes to brown wire from your harness black mirror wire goes to red wire from your harness http://www.6gc.net/forums/index.php?showtopic=21572 Did u use this guide? Your wiring is off. -------------------- |
Lo-Fi Version | Time is now: January 16th, 2025 - 8:09 AM |
