> '97 3SFE Celica - Raise RPM (Maybe a dumb question?), Is it possible to raise the RPM in any method ?
post Feb 17, 2010 - 4:27 PM
jhaletama
Joined Sep 6, '09
From Auckland, NZ
Is it possible to raise the rpm ? this vehicle has no distributor it has 2 coil packs.
once this vehicle is warm it idles very very low like 400rpm, and idleing at so low it almost sounds like its missing....
with a little juice and raising the rpm to about 700-800 rpm she purrs.
again thank you so much to everyone for all your input.
Thank you! Thank you! Thank you!
post Feb 18, 2010 - 4:36 AM
jhaletama
Joined Sep 6, '09
From Auckland, NZ
wat sensor works out the firing of the leads? if i advanced the crank pulley and left the camshafts at there timing marks would that not raise the rpm?
This post has been edited by jhaletama: Feb 18, 2010 - 5:21 AM
post Feb 19, 2010 - 9:15 PM
Remy
Joined Jan 25, '06
From MN
You can raise the rpms by tightning the throttle cable near the throttle body.
"To Protect And To Serve The Wealthy" -POLICE
post Feb 19, 2010 - 9:28 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
There is a little Allen head adjustment screw on the throttle stop. Look for it carefully. It's small.
post Feb 20, 2010 - 1:43 AM
jhaletama
Joined Sep 6, '09
From Auckland, NZ
QUOTE (Remy @ Feb 19, 2010 - 10:15 PM) *
yeah tried that but its at its extreme, how do you alter it at the foot pedal if you can?
Lo-Fi Version Time is now: November 29th, 2024 - 11:17 PM
