Backfiring after installation of hi-flow K&N filter |
Feb 22, 2010 - 5:02 PM |
Enthusiast Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) |
I have installed custom made 3in short intake with K&N filter.
My car now (sometimes, not very often though) backfires. Very loud pop, you can even feel the gas pedal shudder. Usually from neutral to 1st on very low RPMs. It is highly annoying! Also it seems to me that my MPG got worse. Funny, I actually thought that installing after market air filter would IMPROVE it. what's wrong? Has anyone here experienced the same problem? -------------------- '94 ST
Feb 22, 2010 - 5:19 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
did you hook up the air sensor from your old one?
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Feb 22, 2010 - 7:02 PM |
Reset the ECU? Plug in the intake sensor?
Feb 22, 2010 - 7:47 PM |
Yep, intake sensor is in (I'm assuming that is the rounded-spiked-one which was originally in the airbox) and no I didn't reset the ECU because I don't know how.
Feb 22, 2010 - 9:01 PM |
Yep, intake sensor is in (I'm assuming that is the rounded-spiked-one which was originally in the airbox) and no I didn't reset the ECU because I don't know how. pull the "EFI" fuse in the engine bay fuse box, wait 30 sec, put the fuse back in. Drive around. -------------------- |
Feb 22, 2010 - 9:25 PM |
Enthusiast Joined Jan 11, '10 From Chicago Illinois Currently Offline Reputation: 0 (0%) |
lol i ran straight pipe all the way back and mine backfires all the time, i dont see anything wrong with it, i think it sounds quite RAW lol
Feb 23, 2010 - 12:11 AM |
air filter is simply just an air cleaner really, it does not do anything to harm your motor. Unless a sensor or mechanical failure somewhere.
Feb 23, 2010 - 1:47 AM |
I understand. But unfortunately the backfiring started immediately after I installed the setup. It HAS to be connected somehow. @Batman722 I will try to follow your advice. This post has been edited by conus00: Feb 23, 2010 - 1:49 AM -------------------- '94 ST
Feb 23, 2010 - 5:53 AM |
Enthusiast Joined Aug 28, '07 From france Currently Offline Reputation: 0 (0%) |
i you have backfire,try to check your spark plugs, the gap had become too wide on mine, i used a (dont know how you call it, the set of metal plates of different thickness) to get it within specs.
Maybe you have some grease on the sensor too, use some alcool to clean it. |
Feb 23, 2010 - 1:01 PM |
i you have backfire,try to check your spark plugs, the gap had become too wide on mine, i used a (dont know how you call it, the set of metal plates of different thickness) to get it within specs. Maybe you have some grease on the sensor too, use some alcool to clean it. spark plug gapper -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Feb 24, 2010 - 1:17 AM |
^ I understand. But unfortunately the backfiring started immediately after I installed the setup. It HAS to be connected somehow. @Batman722 I will try to follow your advice. thats use to reset the ECU. Did it work for you? -------------------- 94 Celica GT
Feb 25, 2010 - 4:10 AM |
Didn't have a chance yet. Will let you know as soon as I try...
Lo-Fi Version | Time is now: January 10th, 2025 - 3:03 PM |
