> 3s swap , plug with no home with picture, single wire gray plug on driverside
post Feb 27, 2010 - 1:04 AM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
thats the only plug that doesnt have a home, the harness was done by dr. tweaks business, its single gray plug with only one wire and its located between the firewall and the starter, it has no home that i saw , i must have missed something, mayeb this is why my injector wont fire , lol[img=http://img23.imageshack.us/img23/6208/randomplug.th.jpg]
This post has been edited by pxcr440: Mar 1, 2010 - 5:29 PM
post Feb 27, 2010 - 1:20 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
cold start injector maybe? look under the throtle body?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 27, 2010 - 1:29 AM
cjh4l22
Joined Oct 18, '06
From cincinnati
what shape is it? won't fire huh?
post Feb 27, 2010 - 1:33 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
CSI has 2 wires going to the plug, but it wont extend that far to the starter. It has a square plug anyway, and IIRC black and green wire.
The grey plug could deal with the coolant temp sensor. Do you have everything hooked up on the coolant out let neck?
94 Celica gt white (sold)
post Feb 27, 2010 - 1:44 AM
cjh4l22
Joined Oct 18, '06
From cincinnati
dare i ask but its not the plug for the main relay?
and if you get a second can you check out my thread? i'm looking for details on fuel lines routes.
post Feb 27, 2010 - 2:05 AM
post a picture of it.
post Mar 1, 2010 - 6:53 PM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
QUOTE (lagos @ Feb 27, 2010 - 8:05 AM) *
picture is up
post Mar 1, 2010 - 7:48 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Are all of the sensors on the coolant plugged in already?
post Mar 1, 2010 - 8:23 PM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
the two are connected on the front , along with the one in the head on the same set of plugs, there is a one flat spaded sensor on the back of coolant neck, but thats for a simple black flat spade connector withc this isnt , the plug has 12 volts at key one and duriing cranking
post Mar 2, 2010 - 1:21 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
knock sensr?
or oxygen sensor...
post Mar 2, 2010 - 1:36 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
knock knock... whos there?
however your car will still run with that unplugged... search more for the true problem
all your injectors won't fire? will it crank? injectors won't fire if the AFM is not hooked up
This post has been edited by pittfirefighter: Mar 2, 2010 - 1:38 PM
Breaking Axles...
post Mar 5, 2010 - 6:30 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
x2
Knock sensor plug
Verify that you have +12V at all your injectors, coil, igniter.
Check all your grounds (near battery, under intake manifold, etc.)
Sam
post Mar 5, 2010 - 8:22 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Def the knock sensor.....X3
(\__/)
post Mar 5, 2010 - 10:32 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yep now that i see the pic, knock sensor
Lo-Fi Version Time is now: February 20th, 2025 - 6:38 AM
