> Help with stuck rotor
post Feb 28, 2010 - 3:10 PM
NWCelica
Joined Oct 16, '07
From Seattle
Having trouble removing rear passenger side rotor. It's stuck on pretty good..... Thanks
post Feb 28, 2010 - 3:53 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Rubber mallet to knock it loose. If you don't have a rubber mallet you can place a block of wood behind the rotor and hit the wood with a hammer.
**** Photobucket
post Feb 28, 2010 - 4:00 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Had the same prob. One, take off parking brake. Two, there should be holes for some bolts to go through, get the right size (cant remember anymore..been awhile) and thread them till it comes off.
post Feb 28, 2010 - 5:50 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
I use PB Blaster to get my nuts off all the time. Try something like that.
post Feb 28, 2010 - 7:57 PM
NWCelica
Joined Oct 16, '07
From Seattle
Finally got it off ..... Thanks
post Feb 28, 2010 - 8:25 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (Spider77 @ Feb 28, 2010 - 4:00 PM) *
this is the proper way to do it... and easiest... and safest and blah blah blah... thread and tighten... easy as pie
Breaking Axles...
post Mar 2, 2010 - 3:11 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The proper bolt size, if these are stock, are the same bolts as are used to secure the caliper to its bracket -- which makes sense, seeing as how you have to remove the caliper to get the rotor off.
Lo-Fi Version Time is now: February 20th, 2025 - 2:27 PM
