Building the 7A-FE, Lots of pics!!!!!!! |
Mar 6, 2010 - 1:05 AM |
^ I'll give your turbo parts a good home.
'93 MX-5 LE |
Mar 7, 2010 - 12:15 AM |
today we installed a muffler canister. the sound was amazing, nice deep and throaty! we also advanced her timing to about 14 degrees and she is stuck on 91 gas now. but the power increase was nice yes, the timing advance does nicely and pairs GREAT with the ebay header. the timing advance moves the torque down a touch lower and removes the...dead spot down there, the ebay header moves the torque you gain from the timing advance back up a little to peaking around 3500rpm and keeps power from falling off over 4500rpm, finally feels like it dips out at nearer 6000. actually the ebay header with stock resonator and NO muffler sounds quite nice...best sound from a 4banger i think i've ever heard........but i could be biased. This post has been edited by Bitter: Mar 7, 2010 - 12:16 AM -------------------- |
Mar 7, 2010 - 9:22 AM |
I love rebuild threads. Nice pictures too, when I did mine I took a lot but I was more concerned with learning since it was my first rebuild that I didn't take as many as I could have.
Also you mentioned some great details but it might be worth inserting into your first post that its very important to make sure when you take the valves out that you keep them in order and they go back exactly where they came from, in case someone were to use your thread as reference in the future. I didn't use the platigauge on my motor, didn't have much at the time. Its nice to see how to actually use it. -------------------- |
Mar 8, 2010 - 12:56 AM |
glad everyone is getting so much out of these.
Mar 8, 2010 - 1:19 AM |
Enthusiast Joined Oct 4, '09 From Pomona, CA Currently Offline Reputation: 1 (100%) |
Mike, Smaay's friend also did the exhaust tip,
he did an amazing job! This post has been edited by 2celicas2love: Mar 8, 2010 - 1:20 AM -------------------- The heart has its reasons which reason knows nothing of
2000 7th gen GTS 6spd 95 st, swapped 3sgte 3rd gen wrc version :D |
Mar 8, 2010 - 2:21 PM |
wow that seems like 2.5 inch exhaust piping. what are the specs on the exhaust set up??
Mar 8, 2010 - 4:44 PM |
yep, mandrel bent 2.5 from the factory flange to the canister. sounds awesome!
Apr 23, 2010 - 3:47 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
I don't know half of what I'm looking at...but I can tell that it's some thorough work. Very nice. That's exactly what I thought when I was going through the pictures hahahhaah!! OMG I seriously need to hunt you down and get the same service from you. -------------------- |
Aug 2, 2010 - 9:17 AM |
Mods, can we get this added to the stickies? im referring to it alot!
Jan 14, 2013 - 9:19 AM |
Enthusiast Joined Sep 6, '12 From Holland Currently Offline Reputation: 1 (100%) |
Wow amazing! I want to do a rebuild myself in the future.
How did you advance the timing? I know that with my old MR2 the distribitor cap could be rotated, but with my 7afe this isn;t possible. Thanks. And sorry for kicking this old thread up -------------------- |
May 17, 2013 - 4:48 AM |
Enthusiast Joined May 29, '12 From NC Currently Offline Reputation: 0 (0%) |
Do these engines not have specifications? piston to wall clearance, ring end gap, main and rod bearings? i seen the use of a plastigauge which works but is crude. Just looking for clearance spec's, if anyone has them please reply back it would be greatly appreciated.
-------------------- Cleaning and improving my new found yoter little by little. |
May 18, 2013 - 6:09 PM |
Did you also reuse the rod bolts? i read somewhere on here 94-95 you could, but 96+ was tq to yield. Is rod bolts a dealer only part if they have to be replaced, sure seem to be.
May 19, 2013 - 12:20 AM |
yes all the specs are available in the BGB or techinfo.toyota.com yes i reused the rod bolts. they are TTY but they can be used again. this isnt a high performance engine.
May 19, 2013 - 1:43 AM |
Ah i see, appreciate it.
This post has been edited by Takumi-FujiWaraST: May 19, 2013 - 4:31 AM -------------------- Cleaning and improving my new found yoter little by little. |
Lo-Fi Version | Time is now: November 26th, 2024 - 10:45 AM |
