> how to put in a new front subframe/k-frame?, need specifics, thanks alot!
post Mar 5, 2010 - 8:18 PM
mgnt232
Joined Mar 16, '09
Well I got my engine replaced about 6 months ago, and found that part of my front subframe is rotted through! frown.gif
So I want to know how to remove the front subframe? is it simple (I know a bit about cars)
Im hoping I dont need to REMOVE the engine, but Can I just get an engine hoist and support it in place, while I take off the subframe? What exactly is it connected to?
thanks for anyinfo anyone can give to me!
thanks!-
This post has been edited by mgnt232: May 7, 2010 - 3:23 PM
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Mar 5, 2010 - 9:42 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
aslong as you have the engine supported you should be fine. I would probably get someone to help out, those things arnt light.
2nd Gen 3s-gte.... It lives!
97celiman
post Mar 5, 2010 - 10:38 PM
engine hoist would be "ok" but you should really use a brace such as this.
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=96524
you'll have to remove the front & rear engine mounts as well as dismount the power steering rack.
you'll have to disconnect the ball joint @ the steering knuckle and then remove the control arms from the k-frame (subframe)
post Mar 6, 2010 - 7:25 AM
the front and rear mount just stop the motor from rotating.
you dont need to support the motor, the 2 side mounts do that job.
the brace dan suggested above would be pretty much usless, as its designed to support the engine while you remove one of the side mounts.
post May 7, 2010 - 3:22 PM
mgnt232
Joined Mar 16, '09
BUMPING my thread. Got to replace it this month and need more specific instructions on removing and replacing my k-frame
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post May 7, 2010 - 7:09 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
pretty sure you gotta take the ball joints out, unbolt the rack n pinion, unbolt it from the frame of the car itself, and what ever else is connected to it.
97celiman
post May 7, 2010 - 7:14 PM
mgnt232
Joined Mar 16, '09
I know pressure said the side mounts are enough to support the engine, but I just want to make sure lol, cant have it falling on me redface.gif. It seems pretty basic, just unbolt stuff, nothing requiring special tools or anything right?
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post May 8, 2010 - 7:59 AM
QUOTE (mgnt232 @ May 7, 2010 - 8:14 PM) *
i routinely lay under a 3sgte + E153 supported just by the 2 side mounts.
no real "special" tools required.
good luck.
Lo-Fi Version Time is now: December 2nd, 2024 - 3:51 PM
