> Removing Dashboard
post Mar 6, 2010 - 1:27 PM
jbspeed
Joined Feb 6, '09
From Florida
I am trying to remove the entire dashboard from my 95 GT convertible. I've taken out all the screws/bolts I can find, and it seems like it's about to come off, but just won't come. I've searched everywhere and there are no instructions. Has anyone done this? Any ideas?
post Mar 7, 2010 - 5:48 AM
oh lord...
the dashboard is held by 4 black screws
1. bottom left
2. botom right
3. upper right remove small vent cover
4. Upper left, remove big vent
then 2 nuts.
1 is underneath the airbag
2 is undernead the bezel of ignition
then 2 bolts that have the airbag!
you have to remove nearly all the plastics, to get to some of the bolts
to get the dash out, you need to lower the steering wheel
its held by
1. 4 nuts
2. 2 bolts.
next when you have done all this!
disconnect the wiring on the left where the door comes in and the right and those in the middle that go to the main engine harness those cups that hold the wiring on the sides are tricky to take out..
see pics
, take pics, its a tricky process.
cuz this is nightmare
the plastics for the vents have to be removed.
reconecting all is a PITA to remmeber.
i may have forgotten some key points, but its the basic
it took me 3 hours to remove, and voila
the key is to disconect, the wires, its not easy
then paint this, it looks nasty
This post has been edited by njccmd2002: Mar 7, 2010 - 5:52 AM
Lo-Fi Version Time is now: January 14th, 2025 - 11:56 PM
