> Engine Jerking, Engine Jerking
post Mar 9, 2010 - 11:09 PM
GilVilla
Joined Jun 17, '08
From Mexico
I hope you guys can help me with my problem,
I'm the proud owner of a 95 Celica GT std, I have noticed a problem when I hit the gas pedal the engine starts jerking but only between the 1,000 rpm and 2,000 rpm, passing the 2,000 rpm the engine revs up perfectly, I already changed the timing belt, changed spark plugs (NGK iridium), use injector cleaners on the fuel tank and the problem persist, any solution please.
post Mar 9, 2010 - 11:13 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
You mean it like jerks the whole car, and feels as if it is shaking? it might be a motor mount if it feels like the motor is physically jerking
My Celica!
post Mar 12, 2010 - 1:00 AM
GilVilla
Joined Jun 17, '08
From Mexico
QUOTE (jordisonjr @ Mar 10, 2010 - 12:13 AM) *
Well only the engine doesn't want to rev up like it normally does, I don't know how to explain it properly.
post Mar 12, 2010 - 1:06 AM
TinoCel
Joined Jun 3, '09
From North Dallas
At low rpm when accelerating from a stop, is it acting as though your clutch is being popped repeatedly?
post Mar 12, 2010 - 3:50 PM
GilVilla
Joined Jun 17, '08
From Mexico
QUOTE (TinoCel @ Mar 12, 2010 - 1:06 AM) *
No because the engine also jerks when I have the car on neutral or with no gear on, let me take a video of the car and uploaded on youtube so you can see the problem, and thanks for your help.
post Mar 12, 2010 - 4:04 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Did you replace your spark plug wires as well? If so, are you POSITIVE that you put the plug wires back in the correct order? It sounds like you're misfiring.
post Mar 12, 2010 - 4:19 PM
Bigblock
Joined Feb 14, '09
From Mid West
Good tips on the timing // plugs // wires!!
We had the jerky motor, like a noob learning how to drive a 5 speed. It started out like a lil miss, but over time, it got real bad!!
So I PM'd a very respected & knowledgeable 6gc engine guru, and his tip was a tune-up.
Replaced--plugs, wires, & rotor. Smooth as glass since.
Hope it's nothing seriuos. Good luck...
post Mar 13, 2010 - 7:19 PM
GilVilla
Joined Jun 17, '08
From Mexico
QUOTE (Bigblock @ Mar 12, 2010 - 5:19 PM) *
This is the video of engine jerking
http://www.youtube.com/watch?v=FVtBpTrDxb8
Tnks for your help
post Mar 13, 2010 - 8:38 PM
Bigblock
Joined Feb 14, '09
From Mid West
confused.gif Do you have a way to test the injectors? If you have the plug wires on the correct plugs and the correct distributor towers, I am of no help.
Some one with more experience will be able to direct you better.
Good luck
post Mar 18, 2010 - 11:20 PM
alakai
Joined Jan 2, '09
From California
Check your cv joints to make sure they are fully locked into the tranny. I had the same problem and that was the case and while your at it change your tranny fluid.
Lo-Fi Version Time is now: November 25th, 2024 - 9:37 PM
