> Oil Filter Relocation Kit
post Mar 11, 2010 - 5:08 PM
markie
Joined Aug 6, '05
From cerritos, california
Does anyone know where I can get one for a 2nd gen 3sgte?
This post has been edited by markie: Mar 11, 2010 - 5:09 PM
things happen for a reason.
post Mar 11, 2010 - 5:31 PM
QUOTE (markie @ Mar 11, 2010 - 5:08 PM) *
lots of companys make universal kits that will work on a 3s.
the oil filter thread is 3/4-16 (fords and several others also use this thread pattern) so basicly any kit that has that thread pattern on the part that bolts to the block will work.
i made my own for my 5sfte, which is basicly along the same idea as you would need for a 3s, i used the canton racing block adapter and a cheaper trans-dapt filter adapter, and ran SS braided -10an lines with the appropriate swivel seal fittings from earls.
a bit on the expensive side, but provided you run the lines right you should never have a problem with it.
post Mar 11, 2010 - 8:25 PM
celicast95
Joined Dec 3, '08
From Superior, Wisconsin
Is the 5s block 3/4-16 too?
1995 Toyota Celica St- Sold!
1994 Toyota Celica Gt- Sold!
2001 Honda F4I- Sold!
1992 Lexus sc300 5spd!!
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
http://www.summitracing.com/search/?keywor...ation&dds=1
post Mar 12, 2010 - 6:38 AM
QUOTE (celicast95 @ Mar 11, 2010 - 8:25 PM) *
yes.
post Mar 12, 2010 - 10:24 AM
speed-CCNP
Joined Mar 11, '09
From Baltimore, Maryland
Make sure you hook it up correctly and you use the correct hose size. I thought I did. I lost oil pressure and my poor little turbo died. I think I also killed it cause I added an oil cooler too. It gave me an excuse to upgrade the turbo.
Lo-Fi Version Time is now: February 13th, 2025 - 4:54 PM
