> Clear JDM Tails Update, Removed Amber, what 7440 bulb did you use?
post Mar 11, 2010 - 9:30 PM
ChfNix
Joined Aug 12, '09
From Orange Beach, Alabama
So I see a lot people on here with the amber part removed from their JDM tails like this:
and the link on this page doesn't work for me,
I signed up to join their site but it still doesn't work...
Does anyone wanna share how they did it?
This post has been edited by ChfNix: Apr 3, 2010 - 5:41 PM
Failing to prepare is preparing to fail!
post Mar 11, 2010 - 10:33 PM
CelicaST_CALI
Joined Feb 28, '07
From celica club,member Kevstir-
Ok Guys here goes,
Due to not having my Camera I will do my best without some of the picture's I would have liked.
Tools/ Supplies Required
1x 10 mm spanner
1x Gas Soldering Iron with hot knife attachment, here is the one I used
http://www.maplin.co.uk/Module.aspx?Module...D=&doy=20m4
A dremil could be used too.
1x Epoxy Glue
1x Swiss army knife with a Philips screw driver head.
Step 2 , get the hot knife attachment on the soldering iron , once its up to temp get the cluster and turn it upside down here is a picy of where to cut, the hot knife cuts through the plastic like a hot knife through butter biggrin.gif , can also be done with a dremil with cutting disc
Make sure you cut as big a hole as you can to allow enough room to remove the Orange lens.
Step 3, Once you have the top cut away you will need ether a small (small in length) Philips screw driver, I used a Swiss army knife with a Philips head bit, the reason being is that the lens is held in place by one screw(see picy above) that’s in an awkward angle, once that removed its just a case of getting the lens out.
Step 3, get the soldering iron out again, place the plastic bit back in the hole, once u have it sitting right u can use the hot knife to melt the plastic back together, once u have it as good as your going to get the epoxy out and plaster the edges with the stuff to make sure its all sealed, here is a picy of what it should look like once its done.
To do the both sides it took me less than an hour, its easy peezy biggrin.gif
If I missed anything out I am happy to answer any questions.
This post has been edited by CelicaST_CALI: Mar 11, 2010 - 11:16 PM
BANNED. for life, you moron.
post Mar 12, 2010 - 12:53 AM
ChfNix
Joined Aug 12, '09
Wow, don't really wanna cut into my JDM tails, but if that's what I gotta do....
post Mar 12, 2010 - 1:07 AM
TinoCel
Joined Jun 3, '09
From North Dallas
just jb weld it nice and thick, youll be fine.
post Apr 3, 2010 - 5:39 PM
ChfNix
Joined Aug 12, '09
So what bulb are you guys using in there, I used the JDM harness, its a 7440 bulb...
post Apr 12, 2010 - 6:33 AM
cyprus_gt
Joined Jan 16, '09
From Cyprus
QUOTE (ChfNix @ Apr 4, 2010 - 1:39 AM) *
the bulb is 7440 but if you wanet to have completley clear view on the tailights just go and buy 7440 CHROME bulb - but quality one and will be look very nice
cheers
post Apr 12, 2010 - 11:19 AM
ChfNix
Joined Aug 12, '09
QUOTE (cyprus_gt @ Apr 12, 2010 - 6:33 AM) *
cheers
Thanks, unfortunately 7440 bulbs are hard to find in amber in the states. So I just put my USDM harness back in and used a Sylvania Silverstar 1156 bulb and it looks great!!
Thanks for all the help yall!
Lo-Fi Version Time is now: November 30th, 2024 - 7:32 AM
