![]() Enthusiast ![]() ![]() Joined Nov 29, '09 From Milwaukee Currently Offline Reputation: 0 (50%) ![]() |
I was told that i needed a new motor mount because of the vibration noise behind my glove compartment. They said it would be 79.99 labor and i was wondering how much the mount would be....... because i just spent 400 bucks on the front axel cv joint. Im hoping the mount would not cost to much.
Thanks -------------------- ![]() Weekend Warrior-----1998 Celica GT: White Daily Driver----------1997 Celica GT: Blurple |
Enthusiast ![]() ![]() ![]() Joined Nov 8, '08 From Penn Valley,Ca Currently Offline Reputation: 1 (100%) ![]() |
Should not cost more than 100 bucks. How ever it will depend on which one or ones you are replacing.
Well.... the vibration is behind my airbag, so would you no which one that would be?????
lol my bad I just quickly read it.
???? i meant how much would the specific mount be..... there r a bunch of motormounts in the oem catalogue ranging from 30-100 bucks what is the price for the mount in the area which i am having the vibration noise?????
Thanks.... And does this have to be fixed right away????? -------------------- ![]() Weekend Warrior-----1998 Celica GT: White Daily Driver----------1997 Celica GT: Blurple |
Enthusiast ![]() ![]() Joined Jul 23, '09 From Fresno, Ca Currently Offline Reputation: 6 (100%) ![]() |
man im in the same situation.. my mount broke.. so i replaced it from my parts car.
2 days later.. it broke again! now i gotta buy new ones.. and install it...again! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
kirks poly urethane motor mounts are a must have.
i think he only has the front and rear and not the left and right mounts -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
???? i meant how much would the specific mount be..... there r a bunch of motormounts in the oem catalogue ranging from 30-100 bucks what is the price for the mount in the area which i am having the vibration noise????? Thanks.... And does this have to be fixed right away????? There are 4 mounts on the engine. 1 front, one rear and a left and a right. The ones that wear out are the front and rear mounts, and the most common one to fail is the rear one, however you should replace the front and rear mount at the same time. Its around 100$ in parts for both mounts. No, you dont have to fix this right away. You can wait a little while, but youll notice your engine shake more and more over time. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) ![]() |
$80 is a good price especially if its installed, mine were $95 each genuine.
Like lagos said, when they get bad it just makes driving ****, mine were so bad I couldn't take off under 3k and it was ridiculous how much smoother acceleration got when they were replaced. |
![]() Enthusiast ![]() ![]() Joined Oct 22, '08 From St.Louis Currently Offline Reputation: 1 (67%) ![]() |
man im in the same situation.. my mount broke.. so i replaced it from my parts car. 2 days later.. it broke again! now i gotta buy new ones.. and install it...again! That's crazy the exact same thing happened to me. Took mounts off my parts car and two days later they broke. Will polyurthane be stronger? -------------------- -frank
anyone know? mine are sooo bad now. and the ones i need are N/A meaning i have to special order them bitches!! >_<
so... should i just buy kirks poly inserts??? heeelp ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
buy new motor mounts with the kirks...it'll surely last longer. BEN i still need the bolts...
Lo-Fi Version | Time is now: February 21st, 2025 - 5:20 PM |
