Noises, Timing Belt or Knocking? |
Mar 15, 2010 - 9:22 PM |
Enthusiast Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
So my car started making these strange noises espeially when cold, I noticed the noise comes from the timing belt side of the engine. It sounds like a knocking or slapping sound and I can hear it alot more the closer I get to the timing belt cover. Any Ideas as too wat it could be?
Mar 15, 2010 - 9:49 PM |
Maybe this will help if anyone can recognize the noise, The sound quality isn't great and I didn't have a flash light but its right above the timing belt cover
Car Noises |
Mar 15, 2010 - 9:59 PM |
take the timing cover off and look...
Mar 15, 2010 - 10:45 PM |
Enthusiast Joined Dec 16, '07 From Chicago, IL Currently Offline Reputation: 10 (100%) |
Wow that sounds bad! My 5sfe makes some sounds like that in the same area and its due to needing a new timing belt kit. Mine doesnt sound near as bad as yours though. Take the cover off like bitter said. I would get the problem fixed asap if i were u.
-------------------- 1999 Celica GT Hatchback
Mar 17, 2010 - 1:09 AM |
Enthusiast Joined Aug 28, '08 From Woolwich, Maine Currently Offline Reputation: 0 (0%) |
I would get the timing belt changed close to now, sounds like it could be frayed, that sound is similar to the sound my serpentine belt made when it started fraying.
Mar 17, 2010 - 8:07 AM |
Enthusiast Joined Jan 16, '09 From Cyprus Currently Offline Reputation: 10 (100%) |
I have similar problem...there is a plastic cover inside the cover for the timing bell - so this cover have been loose and needet to be fix correctly- so just remove the cover for the timing belt and you will see - and you can check the time belt condition
good luck cheers |
Mar 21, 2010 - 5:28 PM |
Alright thanks everyone turns out my timing belt was cracking the guy said it was close to going out, got it taken care of and the noise is gone =)
Mar 21, 2010 - 7:01 PM |
Enthusiast Joined Feb 5, '10 From ireland Currently Offline Reputation: 0 (0%) |
Alright thanks everyone turns out my timing belt was cracking the guy said it was close to going out, got it taken care of and the noise is gone =) I hope you got your tensioner,idler bearing and water pump changed at the same time as this is a must for this car. it will cost you alot more if any of these fail |
Lo-Fi Version | Time is now: November 27th, 2024 - 1:41 PM |
