Check engine light code., Read the code, how to fix? |
Mar 16, 2010 - 6:17 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Alright so I need some helpy guys, last summer my celica threw a check engine light when i hit a rough intersection. I figured it was just a sensor that came loose. well today I finally got it out of storage and i read the code.
So I used the paperclip technique connecting te1 and e1 and it gave me a code twelve. I fond this link: http://www.off-road.com/toyota/tech/codes/ found in an older topic. My car read out a code 12, and from this link i found on 6gc it says" RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED --DISTRIBUTOR/CIRCUIT --STARTERSIGNAL CIRCUIT --IGNITER/IGNITER CIRCUIT --ECU Now I don't really understand what this means, Im relatively new to cars, and everything has seemed to be working fine since the cel came on. I drove it for abot a month or 2 when the CEL was on last summer, and everything seemed to be running fine, can any of you guys help me out? thanks a lot. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Mar 16, 2010 - 6:34 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
its pretty much the distibutor isnt talking to the ecu, in return you cant get the car started or in my case car doesnt run for more than 15mins
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Mar 16, 2010 - 6:38 PM |
just like the thread i posted in not too long ago (below yours)
here is a link from the stickies on the top of this section of 6gc http://www.celicatech.com/imagearchive/bgb...odes%202.2L.pdf go to page 19 or so about CEL #12 and how to diagnose it Search button helps too -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Mar 16, 2010 - 7:29 PM |
ha sorry, but its weird, its sending a code 12, but my car has been running fine.. i drive it all the time
Lo-Fi Version | Time is now: January 11th, 2025 - 3:46 AM |
