![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) ![]() |
I have my batt located to the trunk...no problems...when i went to go start her up today from storage...the batt was kinda weak but it would crank over...i stopped and tried again to get her to fire...this time all the power went dead...no lights, no dinging noise...nada...so i hook up the charger...and same thing...i checked the fuses under the dash and under the hood....i checked the 100 amp fuse under the hood as well as the rest of the fuses..all good. i grab the voltmeter and start taking some readings....batt is putting out juice at the wires...i track it to the ignition clip and very little juice like .5 volts...so i check the alternator...same thing...i checked the alarm fuses..all good...its like the car went totally dead...any ideas electrical geniuses?
-Rick -------------------- ![]() |
Enthusiast ![]() ![]() Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) ![]() |
are you running a positive and ground from the back to the front or are you trying to ground to the chassis. if you are trying to ground to the chassis i would suggest running a ground line to the front instead. also clean all connections form the bat to where you spliced in in the original location under the hood
it ended up being the ground point underneath my back seat...took it off and resanded it down...thanks for the post though
Lo-Fi Version | Time is now: February 13th, 2025 - 12:16 PM |
